Samsung UN50H6201 panel problem, half screen
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4303
    • Italy - Milan
    #41
    Re: Samsung UN50H6201 panel problem, half screen
    don't worry you have solved, only thing it might be better to enhance the surge protection on the tcon for my opinion.
    • usaNC
      • Nov 2020
      • 7
      • usa
      #42
      Originally posted by Davi.p
      ...better to enhance the surge protection on the tcon for my opinion.
      Is that something I can find on the forum or do you just mean a surge protector?
      I went back in to clean up my tape job (b/c image wasnt perfect) from multiple contacts covered to just one. Narrowed it down to the 5th. Still not perfect (horizontal lines) should I expect a clear image?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4303
        • Italy - Milan
        #43
        sometimes is not pissible to obtain a perfect image sorry. I'm not sure about protections, but i observe a less relaiability in smd components, when a protection item is like so is nonsense, i would put a tht varistor rated at 14v across input protection diode and swap the smd fuse for an oldie but goldie glass one.
        • usaNC
          • Nov 2020
          • 7
          • usa
          #44
          I see. ok thanks
          • usaNC
            • Nov 2020
            • 7
            • usa
            #45
            Given that taping pin #5 gives me a ~95% quality picture. (so panel issue, I assume) Is my set a candidate for the "bypass" wire method? Would it achieve 100% picture quality. I have a Samsung UN55H6350AFXZA
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4303
              • Italy - Milan
              #46
              What do you mean for bypass wire? It is a signal block instead and you already done the 100% of the resut that method can do, so give up and decide if discard the tv or not. I wish to try a new techinque by drill the screen in the faulty portion but there's no more much earnings in repairs to stimolate to explore new techinques spending time..
              • usaNC
                • Nov 2020
                • 7
                • usa
                #47
                using a jumper from cof to panel board, https://www.youtube.com/watch?v=WoWuYaPyit0
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4303
                  • Italy - Milan
                  #48
                  Nooo, that is another story!!!
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Tom C
                    Samsung QN55Q70AAFXZA Half Screen Dim
                    by Tom C
                    I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                    Any suggestions would be appreciated.
                    thanks.
                    09-19-2024, 07:22 PM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
