Insignia NS-LCD47HD-09
  • Butcherpet@yahoo.com
    • May 2018
    Hello all, first post. Got this older TV for free has power but no backlights or picture. Tested voltages and it seems everything is there but the 3v BL ON. I know the inverters are a common failure with the fuses but they checked good on this one. So my guess would be the main board having a faulty component? Or does the BL ON come directly from the power board with the 24v to inverters?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Insignia NS-LCD47HD-09
    BLon is generated from the main board's main IC. There are 2 ways of fixing this: either you need a new main board, or you can try to disconnect the BLon wire from the PSU and jump STBY through a 1k resistor to BLon pin on the PSU (or some other 3 to 5 v source).
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      +1
      Try jumping 3v to that pin somehow. A lab bench power supply or wall-wart adapter makes this easy, just make sure you connect the ground to the chassis. If the light doesn't come on, there's a fault with the inverter. If if does come on, the main board is not sending the BL-ON signal, so you either replace the board (which may or may not be worth it), or grab a 3v signal from somewhere else to "jump-start" the inverter every time you power on the TV....or indeed, attempt to troubleshoot the board if you manage to find the schematic to see where that signal is supposed to come from.
      EDIT: remove the pin corresponding to BL-ON from the main board end so you only send your 3v into the power supply side and not the main board...depending on the connector, sharp enough tweezers can achieve this, since it usually involves slightly bending a piece of plastic holding the metal pin in the plastic connector shell along with the others.
      Wattevah...
        • May 2018
        Ok tried to jump bl on with 3v did nothing. I also see no picture/menu on the screen with flashlight. Just strange to have all the correct voltages besides the bl on. I did notice I have a ribbon cable from the t-con board to the master inverter would that be something to do with the bl on feed thru the t-con? I tried removing the ribbon from inverter then jumping with 3v but still nothing.
          So did you remove the BL-ON wire back to the main board FIRST before jumping the BL-ON pin with 3V?
            • May 2018
            Pretty sure it is the mainboard I tried testing the very thin wires and connectors from the mainboard to t-con and got nothing so the mainboard is not sending anything to the t-con which is probably on the same circuit as the bl on volts.
              The key point is that if the BL-ON is present then the backlights should be on.
              The T-CON gets switched 12V from the main board, that 12V is from the power supply switched 12V.
              We want to know if you have more than just main board or not by testing the power supply board by forcing on the Backlights, but you are not telling us if you did disconnect the BL-ON wire going back to the main board first or not, if you did not you could have damage the BL-ON drive circuit.
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • JSin21
                Compatibility of main boards between different variations of samsung MU6100
                by JSin21
                Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                I have Samsung Smart TV UA65MU6100WXXY version DA01
                Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                11-27-2023, 04:54 AM
