Sony KLV-32 ex-500 Horizontal Flicker/discoloration
  • Chaks
    • Sep 2015
    • 115
    • India
    Sony LCD TV has horizontal flicker/discoloration stripes/bands across the screen (see pictures in the link).
    https://drive.google.com/open?id=1yd...nHul7dyJpu-Yo8
    I have disconnected the TV from all inputs and opened images from USB Pen Drive. But the flicker and discoloration still exists.
    The OSD onscreen text and symbols are clear and discoloration free. There is a slight flicker in the text if we watch it very closely but at 2-3 feet and beyond it is not notice-able. The OSD being clear and proper colored can I assume that the LCD panel is OK and there is some issue with the other electronics.
    Is the discoloration due to bad Power board or Tcon board or the main AV board.?.
    Usually what causes such horizontal flicker and discoloration?
    Thanks a lot for your time in going through this thread.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KLV-32 ex-500 Horizontal Flicker/discoloration
    Look at everything at the left and right sides of the Panel edges, using a magnifying glass. See if there is any discoloration or dirty spot/s formed inside the glass edge/s.
    • rstrube
      ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
      by rstrube
      Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
      Hi Everyone,
      I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
      Yesterday, 01:37 PM
    • rstrube
      by rstrube
      Hi Everyone,
      Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
      Yesterday, 12:19 PM
    • noipi
      samsung Oled 65 Horizontal Lines and Flicker
      by noipi
      I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
      10-14-2025, 02:11 AM
    • russianbar
      SONY KD-65XE7002 Screen Flicker
      by russianbar
      This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
      04-10-2025, 03:11 PM
    • fixit007
      Samsung flicker - BN44-00932T board or else?
      by fixit007
      I picked up this TV that the prior owner said - just died.
      Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
      Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
      Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
      05-04-2024, 06:14 PM
