Saving a Sony Bravia KDL-46X3100 (HELP PLEASE)
  • stevo1210
    • Oct 2006
    • 4156
    Hi Everyone,
    Going around some garbage that's been thrown out in my neighbourhood and I stumbled across a Sony Bravia 46" KDL-46X3100 in good condition. It was clean and seemed to have been wall mounted all its life judging by the missing stand and screw mounts on the rear.
    Took it home and plugged it in... seems to turn on, but I get a fuzzy/double image thing going on.
    I dunno if it's the panel or an IC of some sort that's gone bad? I heard something called T-CON and solder joint when I put it into google.
    Anyone able to guide me here? (Will post photos tomorrow).
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Saving a Sony Bravia KDL-46X3100 (HELP PLEASE)
    Could indeed be panel or t-con. Probably panel....
    You could squeeze the bezel and see if something changes it.
    • stevo1210
      • Oct 2006
      • 4156
      Now that it has warmed up, the images aren't doubling up. Looks all fine and well. However, The left side is darker and redder than the right side??? Squeezing and tapping the panel made no difference at any stage when I tried earlier.
      EDIT: Attached some photos. One at cold start up, one at twenty minutes in when it's toasty warm. It's cold weather here in Australia (winter).
      • stevo1210
        • Oct 2006
        • 4156
        Another few photos for reference. The bottom left corner is darker than the rest of the screen. It still works fine however just very dark and a reddish tint in that corner. You can see a reddish bleed thing in on the left of the panel and IT GOES AWAY when I go into the menu settings, despite still being a black background for that corner - otherwise it is there when video is sent through.
        (The white cropped box contained my name so that's why it's in photo 2)
        • stevo1210
          • Oct 2006
          • 4156
          Now that I am wide awake, I can see the left side of the image is slower than the right hand side of the image?
          I also cracked it open to take a look inside and everything looks fine. Disconnected the four ribbon cables to the T-CON and reseated them and at first i got half a screen of fuzz and half normal. Reseated again and it did what it did before.
          Would I be able to confirm it’s a T-CON issue at this stage and maybe scrounge for parts?
            • 12214
            • U.S.
            I'd go for a tcon, could test your GAMMA voltages and whatever else you can on tcon to help verify.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I thought that if one half of the screen was darker and sluggish it came down to the panel tab drivers at fault.
              What do others think?
                Dick is right. Bad panel. Maybe repairable with a shim but often temporary fix only. If you were going to keep it for a bedroom or something might be a reasonable thing to do. I would never sell one of these TVs with such a fix though. No guarantee of reliability whatsoever.
                  • 12214
                  • U.S.
                  Ok, didn't know that symptom ruled out tcon, well now it's down to strip it down and try a shim, use for you or friends n family as suggested or try selling parts not whole tv. I'm using an old jvc as monitor right now that I shimmed 3 years ago, the picture quality is right on par with panny, sammy, sony and lg.
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Yeah I ended up ditching the TV and put it on eBay. Sold for $1 but buyer reckons he can fix it though. Luckily he picked it up and organised everything - was way too heavy for me to lift to his truck!
                    But alas, thanks for the help anyway everyone!
                    • PopsCaps
                      Sony Bravia KDL-40V2500 that will not power on
                      by PopsCaps
                      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                      I do not hear any sound and I cannot see any backlight.
                      I have tried disconnecting every cable on each board one at a time to see if anything changes.
                      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                      03-25-2025, 11:23 AM
                    • justin35
                      Sony bravia kdl-43w755c - boot loop
                      by justin35
                      i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                      from what i read online it looks to be an emmc issue…
                      i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                      i took out the board and say an samsung 16gb emmc
                      i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                      i could try to put one instead of the 16gb one, but will it work?
                      where do i get the software from?
                      any help will be much appreciated!...
                      03-06-2024, 12:26 PM
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                      10-16-2024, 05:15 AM
                    • Spc.
                      Sony Bravia KD43XF7596BAEP - Android no picture
                      by Spc.
                      Greetings everyone.
                      I also have Sony Bravia, model:
                      Sony Bravia KD43XF7596BAEP - Android.
                      What happend is that image dissapeared while we were watching tv.
                      Diagnostics:
                      1. TV turns on, no errors
                      2. Backlight turs on, no errors
                      3. Power indicator turns on, white color, no errors
                      4. Menu works on android, you can hear sound while switching channels
                      5. Volume up and down works via TV remote and via buttons
                      6. Tunner works, HEVC / MPEG-4 decoder works
                      7. I get audio from channels
                      8. No picture is present,...
                      05-19-2022, 04:28 AM
                    • KYBOSH
                      Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                      by KYBOSH
                      Previous owner said TV just went blank one day.
                      They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                      Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                      The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                      There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                      I just downloaded the Sony KD-75X7800F Service Manual and...
                      11-19-2024, 10:12 AM
