This is one of the cheap sets given to me "sound OK but no picture". I immediately suspected tcon and sure enough this has bottom mounted bonded screen driver combined tcon. But in testing set something strange in that standby (which seems normal) the main caps read 368v and steady. At switch on their voltage starts fluctuating quickly anywhere between 180 - 330v however the 5v and 12v points are good and the leads to LEDs steady at first one 79v and 25v next one 79v and 0v. At no time does screen flicker or show signs of life. I'm not well up on the LED circuitry but the readings don't look right although they are steady whilst main caps fluctuating madly. What are your thoughts.
DSE GE6877 problem with LEDs???
Tags: None
Re: DSE GE6877 problem with LEDs???
Hmm, the power supply has no PFC Voltage booster (I do not see PFC Inductor) so I cannot see how the Voltage measured right between the two legs of the main filter caps can be as high as 368VDC unless your incoming AC; at 240VAC the Voltage on the cap should be around 240VAC x 1.414 =339VDC, so may be your incoming AC is much higher than 240V? 368VAC x 0.707 = 260VAC incoming.
Can we see good clear straight shot pictures of the whole top and the bottom side of the power supply board?Last edited by budm; 05-22-2018, 10:04 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thanks budm and the high voltage we have seen before. I know we sometimes get around 250ac but anyway I used another meter now and this time in standby the main caps fluctuating up to 346v then down then up again so seems to be turning on/off in standby. Set turned on main caps are now reading zero!! But LEDs own power circuit with stable 79v but no lights.Comment
Appears to be a bad string of LEDs. Do you have a LED Backlight Tester?Comment
Thanks budm and the high voltage we have seen before. I know we sometimes get around 250ac but anyway I used another meter now and this time in standby the main caps fluctuating up to 346v then down then up again so seems to be turning on/off in standby. Set turned on main caps are now reading zero!! But LEDs own power circuit with stable 79v but no lights.Last edited by budm; 05-23-2018, 10:01 AM.Never stop learning
What is the Voltage ratings for those 3 yellow caps by LED connectors?
So far it looks like you have open circuit in one of the LED string, the one that read 0V on the LED connector.
You can swap the two LED connectors to see if the 0V reading will follow or not.Never stop learning
No backlight tester Andrew and yes I'm thinking a led strip gone oc. But have been caught recently with two sets I was sure had led problem when they didn't - wasted effort to dismantle only to find all good! Also the circuitry in the ones I've looked at have all been different - with the voltage constantly available to leds at set turn on as in this case why don't LEDs display? I can only think the circuit is left open waiting on the main to activate closure of the circuit (to earth) via PSU.
Anyway whilst awake and fresh this morning and for budm this is what I measured.....
Set in standby, all connected, red led on.
Main caps fluctuating wildly 0-340v, led connectors 60 & 17v. 60 & 0v all steady
Set turned on, all connected, blue led on.
Main caps slower fluctuation 0-33v, led connectors 78 & 34v. 78 & 1v all steady
Main board disconnected, set powered up, no standby led.
Main caps steady at 348v, led connectors 55 & 15v. 55 & 0v steady.
When led connector leads were swapped the voltages stayed with their lead.
The lone black cap near led connectors reads the same top voltage as on the connectors. Cant see its details as that side stuck down. The yellow caps are rated 80v 82uf so would seem to be part of that circuit although voltage rating is low in that case.Last edited by maxvalutech; 05-23-2018, 05:00 PM.Comment
So with the Main Bd. disconnected from the PSU the backlights came On and stayed ON and all other supply voltages were good. If that is so then I would think the PSU is OK and the Main or T-CON Bds have a problem. If the T-CON Bd. is separate from the X-TAB Source Bd/s you could probably try disconnecting the T-CON Bd. to see if the set will power up.Comment
The lone black cap near led connectors reads the same top voltage as on the connectors. Cant see its details as that side stuck down. The yellow caps are rated 80v 82uf so would seem to be part of that circuit although voltage rating is low in that case.Never stop learning
The backlights never came on Andrew and the readings make no sense to me either budm other than the main caps seem to charge/discharge and only when mainboard is connected but the fluctuations are so fast and all over the place so it is difficult to see any pattern to it. At the same time led voltages are steady so cap/s there are holding charge!!! I will pull it apart and check LEDs as I think if 2 strings are there then the readings should be the same and they aren't.Last edited by maxvalutech; 05-24-2018, 12:46 PM.Comment
I finally pulled this screen off the set and got down to LEDs but the white reflective paper is well glued down in places and is brittle so it just started tearing when I gently tried its removal. However from what I could see there is no sign whatsoever of any LED or strip having a problem. This set is not worth much time or effort let alone funds. Am putting it back together and along the way will test with feed to screen tcon long board removed as suggested above (missed that earlier I'm sorry). Other than that then main must be the problem if those LEDs are as OK as they look.Comment
By the way did you notice 11 LEDs x 4 strips and 2 feeds. Couldn't see the actual wiring but strips horizontal so each row 1 x 6 and 1 x 5 ???Comment
No difference with tcon lower board disconnected and same results with voltages being LED leads steady readings and main caps all over the place and yes even 0 voltage reading seen (maybe dmm getting flummoxed!) until main boad lead disconnected then PSU normal. Off to the tip it goes sans PSU.Comment
May be you need to try another meter since no way the main cap can discharge that fast to go to 0V and charged back up fast, there will be lots of inrush current when cap is charging up from 0V, and other circuits that get the Voltage from that main filter cap cannot be steady when the main supply Voltage swings wildly like that.Never stop learning
I have used 2 meters on this one budm the first (post 1) does seem to over read by about 7% when I've compared the two on different sets. There is something very strange in circuitry as LED voltage does remain stable/steady while main fluctuates very quickly but I didn't then check the minor voltages at all since first time. The PSU is OK I believe as it acts normally as soon as main is disconnected. Can never find out any info on these generic sets with store brand and that seller went bust a couple of years ago. Its in dump now.Comment
No to recap as the PSU worked as it should when isolated from main. No circuit info for main and those boards put me off as soon as I see one.Comment
by RofixHello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...12-19-2024, 02:10 PM
I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
Observations... -
by triplefourHello all
got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
anyway i go to this guys house to look at an ONN 100012588
this is my first time looking at one of these brand of TV's.
TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to... -
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
by galentxMy set has been acting up for many months now. The symptom is that the screen randomly goes black and then returns to normal several seconds later. Sometimes it goes black for a few seconds longer and then shows the Samsung startup splash screen before the program returns to the display. The issue is quite variable: sometimes it can go many tens of hours without going black; other times, it will do it 5 times in 15 minutes. The problem occurs with HDMI inputs (any port) and component video. I haven't tested composite or antenna. When using HDMI, the TV is downstream from my audio receiver/HDMI...
- Loading...
