Sharp lc-60le550u weird issue
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I have unit that had no power checked power supply voltage stby at 5vdc and replaced with spare i had,still same.Then i replaced the main board QPWBFX905WJZZ/KD342WJ board.The set fired up ok.I ran it for couple hours everything worked fine ,good picture all options ok.I power off and was going to replace cover turned it around for last test........now back to square 1 ,,,no power.Same problem i began with.
    Re: Sharp lc-60le550u weird issue
    For us to help we will need good clear pictures of the whole backside of the TV showing all the boards, and the straight shot pictures of the whole top and bottom side of the power supply board so we can read the printed texts on the board.
    It is hard to do long distant troubleshooting without seeing what we are dealing with.
    What Voltages did you test so far on the power supply board connectors?
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      I have 2 spares of power supply so i took them out of working unit the display was struck so those were parts units.The spare main board worked for 3 hours and was believed to be working but gave up when i was about to put back on.The unit done a couple strange things before quitting i powered it several times and got sound for few seconds before it went out totally which leads me to question the led strips.I dont have led test strip so thats on list of must haves.The voltages are 4.96 vdc on pin 15 the one with black mark by connector in pic.picture 2.Thats it for voltages.I got it working with main board change out but its not working on that now.I definitely have rule out led strips.
        https://www.badcaps.net/forum/attach...2&d=1526262183
        There are 24 Pins on that PD connector, we need to know the Voltages of each pin except the GND pin.
        Make sure to report the pin name and follow by the Voltage reading so we can easily see the power supply Voltages and the Control Voltages.
        https://www.badcaps.net/forum/attach...4&d=1526262183
        BTW: that PL connector, where does it go to on the other end of the connector?
        That is why we need the pictures of the whole back side of the TV so we can see how the boards are connected together.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          First of all bud thanks for all help.The only voltages i can get is 4.967vdc out of pin 15,the rest are 0vdc on that 24 pin connector.I like just rule out leds as possible problem what pins do i short.i was going to disconnect main board.I assume its 5 vdc and ps_on.
            Pin 13: AC_DET (this is an error signal to tell the main board if the incoming AC Voltage is OK or not) needs to be about 3VDC otherwise the main board will stay in shutdown mode. The typical failure in the AC_DET circuit is due to either bad Opto-isolator or resistor network for driving the LED in the Opto have resistance drifted up.
            • sputnikoff
              • Feb 2016
              • 203
              • canada
              Yes i double checked bud and once i saw 1.3 vdc there then went to 0vdc.I have 3 power supplies on hand so ruled out that as possibility.I removed connector from main board and jumper-ed 14 and 15 voltage on man cap came up to 398vdc .I checked across output for leds bur no voltage present however 85vdc across caps on output to 4 fields of leds.
                You need to have that 3V at the AC_DET pin to tell the main board the incoming AC is OK.
                So i do not understand this "Yes i double checked bud and once i saw 1.3 vdc there then went to 0vdc." AC_DET shows 1.3V and then it goes to 0V? That AC_DET signal is generated by the power supply board and this is common failure in these Sharp TV, there are many thread regarding to this problem. The 3V at AC_DET should be there as soon as the AC is applied to the power supply board.
                You can remove the AC_DET wire from the power supply board and then connect 1K resistor between 5VSTBY and the end of that wire to fool the main board that the AC_DET is OK.
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
                • ugamazing
                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                  by ugamazing
                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                  04-10-2024, 08:06 AM
                • lukkihapsi
                  Asus Vivobook X515JA Weird Boot Issue
                  by lukkihapsi
                  Asus Vivobook X515JA Laptop
                  Issue :
                  Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                  Tried :
                  Cleaned inside for dust, applied fresh thermal paste. No Change!
                  Removed keyboard, Trackpad, fingerprint sensor. No Change!
                  Removed Internal SSD. No Change!
                  Updated BIOS to latest version. No Change!
                  Removed battery and pressing power button for 1 minute. No Change!
                  Weird Part :
                  Upon turning laptop ON, screen lights up - stays black,
                  I...
                  07-07-2025, 12:07 PM
                • Spider1211
                  Weird but interesting issue with DELL 3542 (intel mb 13269-1)
                  by Spider1211
                  Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
                  Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
                  Backstory:
                  Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
                  Power supply draw:
                  Voltage: 19.40V
                  Amp draw: 0.006 - 0.007A
                  Amp draw...
                  04-07-2021, 03:21 PM
                • tommygun26
                  Hp 6510b weird issue
                  by tommygun26
                  Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                  02-26-2023, 06:00 AM
