Panasonic 50S700A 13 blinks, A board?
  • Gingerbread Man
    • May 2018
    • 10
    Hi all.
    I have a Panasonic TH-50AS700A Tv which has decided to play up. It powers on in as much as the screen stays blank, but the red LED flashes 13 times.
    I've been searching through this site and I believe it to be the Main board - Board A which needs attention.
    I'm in Australia and will find a source to buy this from unless there are some recommended sites to go to?
    I have removed the board, and assuming that it is in need of replacement, would it worth attempting to reflow the joints using a stove as a last attempt prior to buying a replacement, or is this probably a wasted exercise?
    Regards,
    David
    https://photos.app.goo.gl/NfiIbO1mjUE0yvPr2
    https://photos.app.goo.gl/bTE3VI60jtScMYuu1
    Last edited by Gingerbread Man; 05-12-2018, 11:41 PM. Reason: Embedded photos won't show. So just posted links.
  • Gingerbread Man
    • May 2018
    • 10
    Re: Panasonic 50S700A 13 blinks, A board?
    Could it be anything other than the A board, or very unlikely?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Main Bd.
      • Gingerbread Man
        • May 2018
        • 10
        Is board A and the main board not the same? I thought board A was the board with the HDMI, RGB inputs etc
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Main Bd. is the A Bd.
          • Gingerbread Man
            • May 2018
            • 10
            Thanks. I'll find one and give it a try
            • Gingerbread Man
              • May 2018
              • 10
              Fitted today. Worked a treat. Legends, thanks.
              • Onionman
                • Oct 2021
                Can you share ur supplier in Australia?
                I have the same TV and problem.
                Can you confirm the A Board is the large board on the left of ur image?
                • lotas
                  • Jan 2016
                  • 4861
                  • Russia
                  A Board - TNPH1077 1 A
                  • Gingerbread Man
                    • May 2018
                    • 10
                    $81 on eBay I believe. TV is still working fine now.
                    • Onionman
                      • Oct 2021
                      Thanks for the reply on ur old post.
                      • Gingerbread Man
                        • May 2018
                        • 10
                        No worries. An email pipes up to say I had a reply!
                          by sam_sam_sam
                          After all of...
                          07-13-2024, 08:14 PM
                        • canadaboy25
                          Panasonic TC-P54VT25 No image. A or D board?
                          by canadaboy25
                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                          01-17-2021, 01:06 AM
                        • Biruslapio
                          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                          by Biruslapio
                          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                          02-16-2021, 09:44 PM
                        • boosti45
                          Macbook pro logic board replacement parts quesion
                          by boosti45
                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                          08-21-2024, 05:23 AM
