vestel smart 40 pf7070 led tv is not working
    vestel smart tv when I plug in the stanbay light does not turn on the voltage does not turn out the socket is going out + 12volt and +24 volts when the controller +12 volts short circuit cause cause I can detect the fault 17mb95 anakart
    Re: vestel smart 40 pf7070 led tv is not working
    this is the motherboard powerbor
      The images are to small. Can you post them again please.
      Görüntüler küçüktür. Tekrar gönderebilir misin lütfen?
        Foto
          What voltages do you have on the pins of PL200
          PL200'ün pinlerinde hangi voltajlar var?
            there is no voltage, but when I remove the socket +12 and +24 volts, the controller shows a +12 volt short circuit
              Check the diodes D318, D319, D320, D321 , D328
                The diodes that you are saying are +12 and +24 volts when you remove the socket to the solid motherboard
                  With the television switched off use your multimeter set to diode mode and check any of the diodes mentioned above to see if any of them are short circuit.
                  Televizyon kapalıyken multimetre cihazınızı diyot moduna ayarlayın ve herhangi bir kısa devre olup olmadığını görmek için yukarıda belirtilen diyotları kontrol edin.
                    Picture the 0 ohm smd pole in picture iscapacitor
                      The 0 ohms smd is a zero ohm resistor which looks as though it is being used as a fuse.
                        Hemen asasigindaki 2 adet smd kutupsuz kondansator kisa devre
                          You need to unsolder them carefully and check them for short circuit. Do not lose them.
                          Bunları dikkatlice çözmeli ve kısa devre için kontrol etmelisiniz. Onları kaybetme.
                            22 nf smd kondansator degisti tv tamamdir thanky
                              Well done.
                              Aferin
