Pioneer PDP-6020FD 3 Red Blinks
  • WeadroW
    • Feb 2016
    • 63
    Hi Everyone,
    I came across this set and wanted to give it a try. Of course, I'm getting a 3 red blink code which does not have much info to reference on the web. I'm thinking this is not one of the common failures of this model. I did find the service manual, and looked through to find what direction I should be looking. I do have a couple questions I'm hoping someone can point me in a better direction. The 3 blink indicates a scan failure. This could be scan ICs, y drive assembly, or x drive assembly.
    How can I narrow my search regarding these boards? What are some key tests that I could do to pinpoint possibly failures? Any voltage test that will confirm any particular failures? Any place to test for shorts?
    Does this set have a “trap switch” that needs to be disengaged when the back is off?
    I've heard good things about this model TV and would like to bring this beast back to life! Thanks for any help! (Sorry about the pic quality)
  • WeadroW
    • Feb 2016
    • 63
    Re: Pioneer PDP-6020FD 3 Red Blinks
    Update:
    I tried testing the unit by checking vsus and vdar. I got 208v on vsus and 74.7v on vdar. I did the same tests with y drive disconnected and x drive disconnected. Both test ended with voltages coming up and a 3 red blink occurred after relay click and power down. So, no change noticed by any board getting disconnected.
    I reviewed the scan ic's multiple times and did finally see a damaged ic. (Photo below) ic is circled in red. Some of the traces I tested do read shorted.
    These “buffers” are bonded to the panel and cannot be removed, so the ic would need to be change while board is in the set.
    Anyone know what would have cause this ic to blow? Really, my question is do I need to fear this same ic blowing after replacement?
    Can this set be fired up with the ic removed to confirm all other operations will function, or will it just go into shutdown?
    What is a good “silicone” to cover the new part with once replaced?
    Anyone know a good source for the ic? Panasonic AN16184A. I see one seller on eBay for about $22.
    These ic's don't appear to be soldered under the chip, just the pins are soldered. So I think my strategy will be to clip the current ic's pins off then solder wick them out of the way. The only hot air unit I have is a heat gun. I could purchase more of a “fine tip” for this if I change strategies.
    Suggestions are welcome if your seeing any red flags with my approach.
    Thanks.
    • WeadroW
      • Feb 2016
      • 63
      I have finally received and installed the new scan ic. Unfortunately, when I was removing the shorted one, I lifted some of the traces off the board. I tried bridging those missing traces with a copper wire to the new ic and thought it was successful. When I fired it up tonight, it did turn on! Whew! But, I have a horizontal line about 2” thick across the screen. Clearly the ic I replaced location.
      Is this something that can be remedied? I figured if anything I might have a row of pixels that wouldn't fire, not the entire ic section. The screen looks great besides this strip. Any suggestions are welcome.
      • mmartell
        • Oct 2013
        • 3189
        How many scan ic's are there in this set ? Trying to figure out if that smallish section of screen is driven by one IC or not. If not then you have some floating pins that need soldering.
        • WeadroW
          • Feb 2016
          • 63
          This set has 16 ICs. The area that isn't working is within range of the IC that was replaced. I know I have 2 pins that are floating because I'm struggling to figure out where I can attach them. The photo below shows one pin. I attempted to remove the surface of the dark green area that it appeared to be attached to but there was no copper underneath. Should I try and just find a common ground or should I try and look under the board for a trace?
          • R_J
            • 9624
            If you look at the other ic's regarding those 2 pins, maybe they will give you an idea as to where they go.
            • Biruslapio
              Panasonic P58V11B 8 and 12 blinks error "fix"
              by Biruslapio
              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
              04-13-2021, 07:13 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • Bushcat
              Pioneer PL-X9 motor speed control wobble
              by Bushcat
              I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
              Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
              BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
              05-24-2023, 03:36 AM
            • EduCabral
              [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
              by EduCabral
              I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
              While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
              🔧 Details:
              • Model: YT-M06
              • Interface: Pioneer 1
              • MCU: Fujitsu MB89F202
              • Goal: Find a valid .bin firmware file or memory dump from a working unit
              I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
              07-15-2025, 12:26 AM
