chirp / squeak noise ... possibly TV?
  • rymik
    • Apr 2018
    Hi
    I have been trying to track down the source of a intermittent and very annoying chirp/squeak noise in my room. I have exhausted all possible mechanical sources (ie plumbing electrical,hvac etc) and the only other thing in the room I can think of is a 4 year old Sony LCD TV which is working fine.
    Ive only noticed the intermittent noise when the TV is on. It will happen only once or twice during a 4 hour span. However, when it occurs, I cant get up fast enough to pinpoint it to the TV exactly... I just know its coming from the general area of the room where the TV is.
    I was able to cut power off to the circuit once while the chirp occurred and after power was removed it still chirped for a few moments so I initially ruled out the TV. Then I realized maybe it could still make this noise since the caps haven't discharged yet?
    So I was wondering...
    Does a intermittent chirp/squeak from an otherwise working TV seem plausible? Failing power supply? And if so, can it occur in standbye or with power removed?
    Im close to pulling my hair out so I appreciate any input.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: chirp / squeak noise ... possibly TV?
    Do you have any other electrical appliance(s) which only switch on occasionally that the TV could be picking up electrical noise either through the air or along the in house power lines?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Cellphone in RFI perhaps??
      • rymik
        • Apr 2018
        I notice complaints online about "chirping" tv's and power supplies....(either the TX or diodes are the cause)... however, those complaints usually associate with non-working televisions.
        Instead of interference, I am thinking a mechanical noise associated with power supply. However, you guys deal with broken TV's everyday and have experience in these things..... have you ever heard a working TV make squeak or chirping noises?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I think I heard one of the newfangled fluorescent ballasts of CFLs do that kind of thing before. It's most likely an SMPS output frequency you're hearing. (or part of a PSU with higher than utility AC frequency, which would be at least after the primary filter cap)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • tony359
            by tony359
            11-28-2023, 05:18 AM
          • MegaZAC
            Onkyo TX-SR805 noise in one channel
            by MegaZAC
            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
            There's some logic behind it. As soon as I select an input I get only left...
            04-23-2025, 10:09 PM
          • courtcircuit
            Philips HTS8000 home cinema noise problem
            by courtcircuit
            Hello
            I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
            Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
            Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
            I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
            Removed each of tyhe boards
            02-08-2025, 08:22 AM
          • protocold
            MacBook Pro 15" 2010 820-2850 intermittent charging
            by protocold
            I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
            I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
            when it is not intermittent:
            PPVBAT_G3H_CHGR_R is 12.07v
            when it is intermittent:
            When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
            when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
            data line on the battery...
            07-25-2025, 08:18 PM
          • roadrash
            Old PC PSU making noise etc
            by roadrash
            A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
            11-18-2025, 09:02 AM
