Good day folks. Bit of help with this telly here ? It's got the PSU in the schematic attached and it's got no power at all. I managed to track down the issue to the standby IC, IC901, a DDA010 which is apparently the same thing as a ICE2QR0665 (datasheet below for your convenience). Initially, I found R902 (slightly above and to the right of the IC in the schematic) had gone open circuit. I replaced it and still get nothing. Now I can only assume that the startup cell inside the IC is not working (page 7 of datasheet explains how it SHOULD work). From what I can assume, during startup the VCC pin sources some current from the drain pin until the AUX winding starts operating on its own and sustains the operation. I'll post some pics of the PSU soon, but for the time being is it safe to assume it's the IC itself that's faulty ? I checked the diodes and didn't get any shorts. The VCC pin appears totally dead - not even "bursts" or startup attempts. Nothing at all, so I don't suppose it's a faulty cap we're talking about. Cheers and thanks.
Delta DPS-214CP PSU no standby (Grundig TV)
Re: Delta DPS-214CP PSU no standby (Grundig TV)
It may be worth reading the last post in the following threadWilling to help but I'm no expert. -
I had a read through it but the difference is that I'm not getting squat, whereas the OP there did get some fluctuations on VCC....I don't have a scope sadly, but from what I can tell, there's no activity on the VCC pin at all....of course I checked all my passives around that IC and they seem fine. I wonder if they ever found a fix. I'll start by replacing the IC then work my way from there...maybe I'll get lucky.
UPDATE: I made another discovery: PC902 has 2v on its emitter pin (the one going into ZD904)...don't know if that's of some major importance though. It's extremely confusing where those 2v are coming from, considering the rest of the circuit appears "dead"...Wattevah...Comment
Have you checked R601 which looks as though it acts as a fuse.Willing to help but I'm no expert.Comment
Output of D902 is dead like I said, since it corresponds to the VCC pin of the IC. Haven't replaced that cap yet, but I'm not getting anything on that line anyway so I doubt it's the cap to blame....for now at least.Wattevah...Comment
If you lift the cathode of the diode D902, can you see any voltage at the cathode at switch on?Willing to help but I'm no expert.Comment
I was going to replace it anyway, though I doubt it's going to be that simple after reading the other post about a similar problem...albeit that one had slightly different symptoms and the OP got some VCC there, whereas I get nothing, no voltage at all on that VCC bus. HOWEVER what I haven't tried so far is measuring that VCC node immediately upon startup to see if it bumps even a little bit. If it doesn't, the startup cell inside IC901 is dead.Wattevah...Comment
What is the resistance between VCC and GND? I did not see hat reading.Never stop learning
Wattevah...Comment
I sent my buddy to the nearest radioshack to look for that IC901 and it turns out it's pretty pricey. Wasn't expecting it to be this expensive. Not sure whether to go for it, esp since it doesn't guarantee it'll fix the issue. Granted, I could PROBABLY find cheaper alternatives online since retail stores by nature have higher prices, makes perfect sense, but I haven't really looked into it too deep yet. If someone has a brainy idea or has got hold of one of these before cheaper, let me know pls
Wattevah...Comment
Since you're a "homie" of mine and I reckon we use the same currency, for comparison, the shop asked 70 RON for it, whereas at Adelaida it would be around 50 RON (+shipping)...not that much of a difference. The guy looked for the ICE one as well, not the original DD. It's up to the client at the end of the day....Wattevah...Comment
With D902 cathode lifted what voltage does VCC pin of DDA010 reach. The internal charge pump should be outputting a voltage to charge C903. The internal charging circuit then switches off when C903 voltage reaches => 10.5V typically.
Do you have the B+ voltage on pins 4 & 5 of the DDA010Willing to help but I'm no expert.Comment
This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
by JunkrepairI'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
I found this nice little description of the conversion:
Calculating capacitor ESR from Tan(delta)
https://forum.digikey.com/t/calculat...-from-tan/2633
It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...-
by LEECH666Good day ladies and gentleman!
I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
I think the PSU buzzing comes from one of the coils near the bridge rectifier but... -
This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 06:11 AM
This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
- Loading...
