Panasonic TX-47AS650E Blinks 1 time , Replacement LED?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Bought a defective 47 inch Panasonic LED tv real cheap. Planning on repairing it for sale.
    I normally repair Panasonic plasma's but i took the gamble on repairing this model.
    Tv starts up and gives a image but it shuts down after a few minutes. Before it shuts down the backlight starts flickering and i noticed a black bar in the backlight so 1 row is not working. Tv shuts down with 1 blink ( protection ).
    So im 100% sure the LED's are failing or maybe a bad connection. These models are famous for that. Have not opened up the tv yet but im planning to replace just the LED(s) and not the strip.
    What LED do i need , are there common LED's like the Osram duris E5? Or can i find the type of LED on the strip?
    Anyone repaired this model before? If so what LED's did you use?
    Im asking this because removing the panel is something i want to do only 1 time. ( Minimal chance on ruining the panel ).
    Thanks.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TX-47AS650E Blinks 1 time , Replacement LED?
    They are being sold as " V14 S DRT P 47 R2 L2 LED strip ".
    Need to know what the LED name is.
    • vinceroger69
      • Mar 2012
      • 6714
      I have been using aliexpress for leds but this seller on ebay is really helpful send him a message with the led strip number thats used in the tv im sure he will advise the main thing also is getting the correct led footprint as anode/cathode has one pad larger than the other.
      https://www.ebay.com/usr/microtech-a...p2047675.l2559
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Thanks alot , i have send him a message. Maybe i need to open up the tv , might be a loose contact as the tv turns on fine but shuts down later on.
        • vinceroger69
          • Mar 2012
          • 6714
          yes maybe a bad contact a lot of people hard wire the led strip joint connections.
          reece has a video on youtube showing how he does it.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Yes i have seen that video. Will open up the tv and see if the leds are bad. Thanks Vince.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              If you want to open up this panel only once as you said then, if I may recommend, replace ALL the strips and not just the failed LEDs. I have sometimes found that replacing the failed LEDs will work for awhile and then the others that seemed good will start to fail one by one.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Thanks! Replaced the led with one from a 32 inch AS600. It had edge light.
                Tv works but the colour of the led is different. Waiting for the replacement leds.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  If it's edge lit, I believe it's one of these LEDs ?
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • Biruslapio
                    Panasonic P58V11B 8 and 12 blinks error "fix"
                    by Biruslapio
                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                    04-13-2021, 07:13 AM
                  • signal.quest
                    Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                    by signal.quest
                    I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                    03-17-2024, 10:14 AM
                  • Jagster
                    Panasonic SA-XR25,Looking for a good replacement cap
                    by Jagster
                    I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
                    The sleeve info:
                    10-27-2022, 09:34 PM
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
