White Reflective sheet for LED backlight?
  • cagey1two3
    • Mar 2018
    • 14
    Hi Guys, I appreciate that this is not strictly a technical issue, but I'm stumped and could do with some help.
    I've just disassembled my Panasonic TX-42AS500B and diagnosed some failed LED strips, which I have now ordered so I can replace the dead strips.
    Whilst I was disassembling the TV the bottom most white reflective sheet (not sure if that is the correct name for it, but it is the one with holes that covers the led strips and chassis) was glued to chassis and damaged in parts when removed.
    I am now concerned that when I reassemble the TV, LED lamps wont be reflected correctly. I'm looking for a suitable replacement or some plastic/card i can purchase and repair it.
    I have sourced some optical reflector film in china but that comes in large rolls and I litterally am only in need of an A4 size to patch up the damaged parts.
    Any help or guidance would be much appreciated.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: White Reflective sheet for LED backlight?
    I've just stripped down a laptop LCD and the backing piece of white seems similar to the stuff behind TVs. If you don't have access to similar I could post a couple of pieces in the post to you ?
    • cagey1two3
      • Mar 2018
      • 14
      Thanks for the offer diif, I have left you a PM
      Cheers
      • cagey1two3
        • Mar 2018
        • 14
        Just want to say a big thanks to badcaps forum and an even bigger thanks to diif for the kind offer.
        Cheers all...
        • lfhlaw
          60LN5600 white reflective sheet
          by lfhlaw
          So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
          Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
          Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
          05-23-2022, 07:14 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • DanPoka
          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
          by DanPoka
          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
          MSI Trident 3 White 8RD-048 Trident i7-8700 Specification for Upgrade or Repair
          This specification for the MSI Trident 3 White 8RD-048 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 White 8RD-048 boardview and Trident 3 White 8RD-048 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-12-2024, 03:28 PM
