Panasonic Vierra frequent EEPROM corruption
  • jesterace
    • Aug 2013
    • 87
    Hello i had some trouble with a Panasonic LCD TV a few months back and after a lot of trying i figured out that doing a factory hard reset cured the problem. The TV originally wouldn't come on and kept flashing it's red LED.
    PANASONIC TX-LR32C3
    Panel: VVX32H100G00
    PSU: TNPA5361AA4P
    Main: TNP8EA112
    I used the following reset sequence:
    Turn the TV off.
    Hold the F button and Vol- button on the side. Then hold the power button (also on the side).
    Wait for 3-10 seconds for the backlight to come on.
    The TV has worked for perhaps a couple of months since doing the reset but now the problem is back. Would replacing the two EEPROM ic's that this set has be a sensible step to take? I have various programmers that im sure support these chip models.
    IC's are: 24С16, 24С32
    I'm not 100% sure why there are two or what each ones purpose is but i'm guessing that when you tell the TV to factory reset, one or more of these chips has their data cleaned up/settings wiped? Would it be logical to think that maybe one of these has failed causing regular corruption?
    or any other ideas? Help much appreciated.
    Thanks,
    James.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Panasonic Vierra frequent EEPROM corruption
    It's not going to hurt replacing them and they aren't expensive.
    They have a finite lifespan, so it's possible it's failing or the data is corrupt.
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
