about samsung color issue
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hello Mate
    I am working on this samsung panel, when i power it on it will work fine picture ok, but after a while the picture will shake then color will change to what you are seeing on this pictures, please i need help
    Hispeck
    Re: about samsung color issue
    https://www.badcaps.net/forum/attach...7&d=1521487478
    It looks like some of the traces go damaged, you can see the white silkscreens are scarped off.
    BTW, is this board on the bottom edge of the LCD panel?
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      yes , i forgot to explain it, i did it when i thought cutting can make a change the tracks you see that was cut was done by me, but is not from there
      thanks
      • hispeck
        • Aug 2015
        • 258
        • nigeria
        should i return the set back to the customer?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4318
          • Italy - Milan
          I dont see which defect has from my tablet, can't you explain it in words?
          • hispeck
            • Aug 2015
            • 258
            • nigeria
            what i mean is that this tv will work fine in the first 20 mins after the color will change to what you see on my post, when i put it off and power again the same thing
            hispeck
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Check voltages: 1. Von = 20V to 35V, 2. Vdd = 3.3V, 3. Vda = 13V to 25V,
              4. Voff = -5V to -8V and 5. Vcom = 7V on the T-CON Bd. These should be present and if varying too far of from these then your problem could be off the Level Shifter IC. You could try cutting off CKV1 and CKVB1 as a pair, strapping and connecting to STVP or GND the. CKV2 and CKVB2 as a pair. For me those points are very fine and I attempt to do that kind of panel repair very rarely. Good Luck, though.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                I repeat the pitcures of screen image are not so esplicative, is seems only an old movie with poor quality film..
                • hispeck
                  • Aug 2015
                  • 258
                  • nigeria
                  Thanks friends,
                  you have done well by replying me, i tried to cut ckv1 and ckvb1, but the picture after a while will have white horizontal bar once the menu appears or any wright up shows on screen, i read about strapping the cut pair to voff or gnd, please i need help on how to strap this very panel after cut.
                  sometime when i cut double image on same panel the screen will have some tin lines, because i dont know how to do the strapping thing, i end up not fixing this panel. please i will be grateful if i can get assistance with picture if possible.
                  thanks
                  hispeck
                  • hispeck
                    • Aug 2015
                    • 258
                    • nigeria
                    on how to strap and where to strap after cut
                    • hispeck
                      • Aug 2015
                      • 258
                      • nigeria
                      Andrew,
                      you said i should connect the cut pair to stvp or gnd, some people say connect to voff and gnd, please which one is right to do?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4318
                        • Italy - Milan
                        I don't undersand theese procedures. CKV1/2, CKVB1/2 are clock signals for the gate drivers, if one cut them or put them to GND i guess is like shutting off all gate drivers so you will end with no image... STVP is approx. the starting signal for the gate driver 1, which is the meaning of joining it with the clock signals?
                        • hispeck
                          • Aug 2015
                          • 258
                          • nigeria
                          So what do you advice Davi.p concerning the problem am talking about? like i said after cutting ckv1 and ckvb1 i get tin lines on screen, some say strap the cut line going to the panel to voff or gnd, please give me your own opinion what you think is best for me to do and achieve result
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4318
                            • Italy - Milan
                            As already said, i'm unable to recognize this fault from your simple pictures, more screen pictures needed, also magnified ones..
                            Also never forget to mention THE TV MODEL.. Also a text explanation of the problem would help, i can point to a defect of missing horiz. lines but photos are so poor...
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              CKV1,2,3 and CKVB1,2,3 are cut in pairs. That is CKV1 and CKVB1 is a pair as is CKV1 and CKVB2. So for example the cut is done on CKV1 and CKVB1 first. The cu tis made to separate the signals output from the Level Shifter IC to the input at the Panel. Strapping takes place on the Panel side and connected to Voff and if that does not work try GND. If that did not work reconnect the cut connections and repeat procedure with CKV2 and CKVB2
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4318
                                • Italy - Milan
                                I don't understand the theory of that explanation, so cutting first CKV1+CKVB1 (gate drivers clock signals) and join them to Voff or gnd, which sense has this?
                                • hispeck
                                  • Aug 2015
                                  • 258
                                  • nigeria
                                  Thanks all for your support, i feel loved with your corporation
                                  Hispeck
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4318
                                    • Italy - Milan
                                    hispeck i don't understand you...... why not to add some pics?
                                      09-07-2024, 05:50 AM
                                    • vincentedel
                                      Samsung SyncMaster 740n Phase Control Issue
                                      by vincentedel
                                      I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                      I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                      04-22-2025, 12:33 AM
                                    • Manucsl
                                      QE65Q800TATXXC Samsung TV Issue
                                      by Manucsl
                                      Hello.
                                      My TV is a QE65Q800TATXXC Samsung TV.
                                      Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                      Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                      Any ideas to check would be very appreciated 😊
                                      After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                      02-19-2025, 07:47 AM
                                    • FourRunner
                                      Display issue Samsung TV UA65JS9000W
                                      by FourRunner
                                      I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                      10-03-2024, 07:05 PM
                                    • ScHAmPi
                                      Samsung UE48JU7000 screen issue after backlight replacement
                                      by ScHAmPi
                                      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                      07-15-2024, 05:41 AM
