Plc-xe40 projector help
  • jmh474
    • Aug 2016
    • 46
    • uk
    HI all so iv been given two Plc-xe40 projectors and I can't get one of them to fire up..
    Iv looked over the service manual and from what I have read I'm a little bit confused, as it shows that the warning LED will come on if the projector senses a problem but this is off.
    Iv looked over a few problem places like lamp don't look blown , thermal cutout continuity across contacts, cover switch continuity across contacts when closed so all look good.
    One of my other problems is that iv have NO REMOTE for either of them, so iv used an app called Zaza universal remote but still nothing, there are also spaces on the MB for different push button switches, iv tried linking the power switch over but still nothing.
    So I'm at a bit of a loss on what to do next.
    I'm also thinking about replacing the lamp with a high power led, as a new lamp costs over £90, I know I'll have to bypass the ballast some how but this is something that I'll look into after iv got one working, any advice on this would be grateful.
    Thanks for any help
  • jmh474
    • Aug 2016
    • 46
    • uk
    Re: Plc-xe40 projector help
    Any one have any ideas at all please :-(
    • budwich
      • Jul 2015
      • 3097
      well the most obvious would be, take one apart and check things out with a meter, checking for voltages that are printed on the board(s) and go from there... also checking any fusing. Without a remote, it would seem like you are going to have an issue since it appears that the units have no power on button. Further, IF someone has set a security code, then you are further "screwed". In addition, did you try the reset button.
      • jmh474
        • Aug 2016
        • 46
        • uk
        Yes iv tried the reset button to no avail, I was hoping to find a way of linking out something inside on the MB to bring the projector on, as iv said there are places for push button switches inside, looking over the service manual these buttons should work when linked out, as the manual has pcb lay out for the projector
        • vestaviascott
          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
          by vestaviascott
          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
          Here's what happens:
          1) Power on
          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
          3) Blue status light flashes for appx 4 minutes...
          07-29-2020, 06:08 AM
        • platinumsteel
          Epson VS250 Projector Lamp Not Working.
          by platinumsteel
          Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
          04-09-2023, 04:03 PM
          Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
          09-06-2024, 06:11 AM
        • Mc_Millian
          Toshiba 50lf711u20 fire tv remote not pairing
          by Mc_Millian
          I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
          The Tv model number is: 50lf711u20 Rev B.
          I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
          I've tried 3 different remotes which should be fully compatible with this TV.
          Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
          The power button, along with the volume,back,select, and directional...
          04-07-2022, 12:15 PM
        • magnetepazzo
          epson emp-x52 projector lamp temp fail
          by magnetepazzo
          Hi Guys i have this projector emp-x52 when power on the fan spin and lamp go on but after few seconds lamp go off and led temp flashing with fan at maximum speed. I have check the 2 termal temp but are good are 12.51 Kohm. Have suggestion for me ? TKS
          04-23-2021, 03:37 AM
