Samsung LNT4671F 4671FX/XAA Horizontal picture skipping...then I screwed up
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    The other night I saw this TV for free on a local website. It was close, so I picked it up.
    The symptoms were a picture that was horizontally choppy and jumpy. On initial start-up the channel would display in the corner. Everything looks fine until the picture starts...then it goes horizontally jumpy, menu and all. It looked like the TV was confused upon the horizontal placement of the picture on the screen, like the horizontal hold being off on an old CRT set, but completely unstable and unpredictable. Sometimes the screen is split in multiple horizontal layers that randomly and constantly change.
    Upon the background picture going black, like during a gap between programming or by disconnecting the coax from the "megatenna" the menu was stable 99% of the time, with only an occasional glitch in its placement. The picture would stabilize for a few seconds with a less intense or darker picture on the screen, like before "Just For Us" cuts to the show name the picture is "confused". When it goes to black and the show name drops in on the right in yellow it shows perfectly.
    Unfortunately the operative word here is "WAS".
    I have no idea what this shart for brains was thinking, but after a little research I began pressing on the cable connections at the t-con board. I thought I noticed a change in the picture stability, so I lifted the lock bar at the left ribbon cable and pulled it out.....with the TV still on. If that weren't bad enough I stuck it right back in with it powered up. I saw an arc on the strip....and wound up with the descriptors above.....and a solarized screen. A little later and now there's no picture. Backlights on, black screen.
    Unplugging that infernal thing with the unit on was completely stupid. Messing with it further earns me the title of shart for brains of the day, at least.
    I'm just wondering if I put the final toasting on a t-con board that was already bad to begin with, or did I just fry it in to oblivion? Thanks for helping the "Technologically Challenged"!
    They call me......."threadkiller"
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Samsung LNT4671F 4671FX/XAA Horizontal picture skipping...then I screwed up
    Also the processor chip on the t-con is stone cold, like the board isn't powered up. No voltage on output side and input side hovers around 1.2v dc. Help?
    • freakaftr8
      • Oct 2012
      • 3743
      You probably took out the gamma processor on the tcon. The jumpy horizontal picture is most likely caused by a badd panel to start with. This model does not have horizontal tabs drivers so it requires the source drivers to deliver data to the horizontal quarter of the screen. You might have a badd connection on one of the source driver tabs that are fused through the panel. You could try taking the metal frame off and pressing on the ribbons gently where they attach into the panel itself especially on the far right and far left ribbons. Right there is a chance that you could have done damage to the panel by removing and re attaching the ribbon.
      Look for a chip on the tcon labeled AS15.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        The only A designation I see is AR15 on the tcon. Is that what got cooked?
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          OK I found it. And the color green of this t-con board does not match the green on the rest of the boards. I can't seem to find a date or date code either, but the other boards have dates within a couple days of one another. Does that mean this is a replacement t-con possibly?
          • freakaftr8
            • Oct 2012
            • 3743
            Possible but When a panel is manufactured, the tcon always goes with the panel then you add the subassembly boards and the frame to complete the television. So it is very possible that the t con will not match the other boards.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              Do you think my screw up cascaded down to the logic and main boards?
              • freakaftr8
                • Oct 2012
                • 3743
                Doubt it. Mainboard is probably fine. But there's a slight possibility that the skipping can be caused by mainboard thou.
                  • 12332
                  • U.S.
                  http://www.shopjimmy.com/samsung-bn8...-con-board.htm good pic.
                  Maybe test the fuse on the tcon too, labeled F1.
                    • 12332
                    • U.S.
                    https://www.youtube.com/watch?v=yTnkOfwBGGE tcon testing.
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      Could that explain the same glitch with the menus? They jump around on occasion too. Or is that from the logic board?
                      I checked the videos out, thanks for posting the link. I've been looking at the t-con board for an hour and I can't find a fuse marked F1. Can you give me a general idea where it is?
                      I need a lighted magnifying glass soooooo bad.
                      • will62
                        • Dec 2016
                        • 229
                        • usa
                        Does this one look like yours?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Yes the glitch can be caused by a bad mainboard with the flickering in the vertical jumpiness, Although this could also be a problem with the LCD panel itself as there could be a driver failing inside the panel, Could also be a tab bond failu re.
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            Yes that looks like it.
                            Right on. It still has good parts in it so it's not a loss at least!
                              • 12332
                              • U.S.
                              No problem, hey diif look there, seems like the videos ARE pretty useful after all.
                                • 12332
                                • U.S.
                                Our "pal" diff, said they were useless, ummm I guess because you can't see what they are doing but most of them are very well done. "My pal" diif just informed me that "pros work for cash" maybe that's why he never helps and is always begging for leds.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  lets all be friends for crying out loud.....
                                  <--- Badcaps.net Founder
                                  Badcaps.net Services:
                                  Motherboard Repair Services
                                  http://folding.stanford.edu/
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • DXseekerMO
                                    • Feb 2018
                                    • 1119
                                    • US
                                    Heck there boss you are about 80 miles from me!
                                      • 12332
                                      • U.S.
                                      n/a
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16959
                                        If you're ever passing by the area, shoot me a PM.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
                                        • YellowJacket
                                          Samsung QE55Q60RAT - no picture
                                          by YellowJacket
                                          Hi friends,
                                          a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                          07-30-2024, 01:31 PM
