LG 50PS60 Sound but no picture Ysus board EBR6183001
    Re: LG 50PS60 Sound but no picture Ysus board EBR6183001
    The signal looks fine to me, but it's not synchronised with the VS_DA point right now. Can you try triggering off VS_DA, using CH1 for VS_DA and as the trigger source, and CH2 as your Y-sustain output? You can try adjusting the TRIGGER LEVEL (making sure trigger source is set correctly and mode is on AUTO) to see if you can get the scope to lock onto the trigger properly.
    Your issue with the channel attenuation setting being intermittent isn't uncommon, and can usually be fixed by using contact cleaner on the switch. As you note, you may have to disassemble the instrument to access this part.
    • goldbird78
      • Feb 2018
      • 188
      • canada
      #82
      Just want to make sure I am accessing the correct VS DA test point on the control board. I circled below in red.
        That is correct. I am wondering if the signal might not be making good contact; you might want to consider scraping off the "solder mask" in that area to reveal the copper so you can solder a wire to it, carefully.
        • goldbird78
          • Feb 2018
          • 188
          • canada
          #84
          Yeah, I did that and the signal doesn't change. Lets put this on hold for a week or two until I get a good digital scope. When you have a chance let me know what your opinion is on the below topic. That is this weekend project. I appreciate all your help.
          https://www.badcaps.net/forum/showthread.php?t=68034
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
