LG 50PS60 Sound but no picture Ysus board EBR6183001
Re: LG 50PS60 Sound but no picture Ysus board EBR6183001
I need one of the opposite side of this showing the white connectors
https://www.badcaps.net/forum/attach...8&d=1520190112Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ok you'll want to probe either side of that green resistor on the left hand side...just near the silver capacitor and the big red capacitor, and the text "SOLDERING"
Settings for probe: Switch to 10X (if switchable), if not check the probe says 10X (making it a fixed 10X probe which is fine), black lead on probe connected to the chassis of the TV, the frame near the Y-buffer board usually works ok. Probe on the points mentioned above.
Settings for scope: Trace focused and centred (use beam finder if available). Trig auto mode. 10V/div (equivalent to 100V/div on 10X) for channel 1, with probe connected to channel 1. Sweep on channel 1, turn off dual/chop mode. Time 500us/div. If there is a 10X scale for the horizontal, turn it OFF. Coupling for trigger DC. Coupling for channel should also be DC.
When the set turns on, you should see something filling the screen. It won't be stable for now, but we need the second probe to sort that out. Hopefully you have one. If not, we will need to try to find the best trigger setting to get a stable display.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Attached is what the scope was reading before and after the resistor. And my Oscilloscope settings below and in picture. Yes I do have a second probe.
Ch1 set to DC
Volts/div set to 20 and middle knob pulled out for x5
Vert mode Ch1
Sweep mode Norm
Slope Positive
Coupling DC
Source Ch1
A Sec/Dev set to 50 and middle knob pulled for x10
B Sec/Dev Set to .5 but know idea what this should be or what it does.
Hor mode AAttached Filesif you find these attachements useful please consider making a small donation to the site
Set sweep to Auto.
Hor mode to "A"
Vert mode to CH1
Set all "CAL" dials to calibrated position (until they click at CAL)
Trigger source to CH1
I think "A" time is most important on this scope, "B" time is only for delay time, and not relevant for this application.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Done. attached is what I am getting on the scope before and after the resister
OK, show me what you get at 5ms/div...starting to look more reasonable now.
Can you also attach a pic of your control board. Need to locate the VS_DA point.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
See pic
OK, your VS_DA point is just to the right of the main big chip on that board.
Show me the 5ms/div trace and we'll go from there.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Here you go. Thx
wait, was that the plasma Y-sustain output or VS_DA?
Think I may have confused you - still want you to probe Y-sustain output - but keep an eye on VS_DA for future uses...just need to make sure you're all set up first...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
previous was the VS_DA, Attached is the Y on both sides of the resistor.
Cool, that's looking a lot better
OK, now hook up the channel 2 of the scope up to VS DA.
Set trigger source to channel 2
Set trigger coupling to AC and set the trigger level to the centre position (zero)
The waveform should now be a lot more stable, is it?
You may want to find a way to keep the probe on VS-DA...such as soldering a wire to the pad or a nearby component or enlisting a trusted helper...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Done, It looks a little better but I noticed there is not much difference when I remove the probe from VS DA
You may want to find a way to keep the probe on VS-DA...such as soldering a wire to the pad or a nearby component or enlisting a trusted helper...Attached Filesif you find these attachements useful please consider making a small donation to the site
OK, now set the time base to 1ms/div.
We want to see a waveform that is "locked" in time. So the scope starts at the same point on the waveform every time.
An oscilloscope normally uses a trigger signal, like VS_DA, to synchronise the scan of the electron beam across the display.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, I have also included a .1 & .2 ms/div. See pic's
An oscilloscope normally uses a trigger signal, like VS_DA, to synchronise the scan of the electron beam across the display.Attached Filesif you find these attachements useful please consider making a small donation to the site
Are you sure your probe is set to 10X? As the waveform does not look correct for a 10V/div setting. It is way too large - should only be filling around four squares vertically on the display. Also, check the CAL dial for the respective channel is locked in the CAL position.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... - Loading...
