Sharp LC-60LE831U LED's
  • zdsh07p9
    • Nov 2013
    • 155
    Does anyone have one LED strip from a LC-60LE831U with 80 LED's on it that's working that they'd like to sell? I need one more...
    I dont know if this is the correct place to put this but I figured it was worth asking with so many TV Guru's here
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • JayPoorJay
    Sharp 70' LEDs Spike 260v at start up?
    by JayPoorJay
    Hi all. This is my second thread. Have a bunch of questions.
    I got my hands on a 70 inch Sharp Aquos LC70EQ10U. Not working when I found it.
    I replaced the power board (found in eBay) and the TV finally produced an image. Reset it had image and sound.. Went from 2 slow and 2 fast blinks as a fault code to 1 slow 1 fast fault. Lamps or inverters according to the manual. TV is one now, at this moment (looks great w/ ZERO dark spots on screen) but it powering up and producing an image is unpredictable. 3 out of 10 times.
    There are 3 leads to the LEDs....
    02-01-2022, 05:04 PM
  • Easky15
    Sharp LC-39LD145K No Power to LEDs
    by Easky15
    Hi all, Been a while since ive had to use this forum,
    I have here a Sharp LC-39LD145K that works fine apart from no power to the backlight LEDs, I have stripped it right down and tested all LEDs and they all work fine, I can see them flash briefly for a split second when powered up, the voltage to them slowly drops away after the flash so im guessing there is an issue with the power board,
    I think the model number on that is 17IPS20 and here is some pics of it
    Any help on this would be greatly appreciated,
    Thanks...
    05-10-2020, 07:11 AM
  • THE GTC
    Insignia NS-37D20SNA14 intermittent LEDs
    by THE GTC
    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
    11-03-2020, 02:40 AM
  • pni
    Backlight panel diffuser melt by backlight leds broken
    by pni
    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
    10-12-2025, 12:08 AM
