PN64E533 powers up with sound no picture
  • freakaftr8
    • Oct 2012
    • 3743
    Hey guys.
    So this one has VS but drops off right after I hear the Samsung chime. This one is not the infinion IC, but C5050 was the issue. I replaced all 5 around the area for good measure.
    They were originally ceramic, replaced with 50v 10uf electrolytics.
    Worked like a charm.
    • 12276
    • U.S.
    Re: PN64E533 powers up with sound no picture
    Very cool, I didn't know you could swap those type caps
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Nice work What were the original Ceramic values. And yes you can replace non-polar caps with e-caps.
      • freakaftr8
        • Oct 2012
        • 3743
        Thanks guys. Original values were 106
        The trick is using it your DVM to locate which side is ground if you want to use polarized lytics. I have used these before in low power applications and found that they are just as reliable.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          I used radial caps myself on one of these. Works great! Time to find a buyer$$$$
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
