Sony bravia xbr-43x830c
  • Martin0101
    • Feb 2018
    • 21
    I have this tv that is complete dead.. it shows no power at all. No stanby light.. i checked the power supply voltages with the harness connected to the main board and here are the only voltages i get... need help to find out the problem..
    Bl-err 2.38v
    Stby 3.47v
    Ac-off-det 3.47v
    • 12332
    • U.S.
    Re: Sony bravia xbr-43x830c
    Looks like you started another thread on same tv, what you want to do is just post on your same thread. That way all the posts are in one spot and can be easily read. An easy way to find your thread is use the thread tool and subscribe to your own thread, then it's easy to find in quick links.
      • 12332
      • U.S.
      Originally Posted by will62 View Post
      You may want to check a little further before buying a new power supply. This set has a self diagnostic function. When the uC detects a problem, an LED flash code is produced. You said that you had no LED status light. If you have standby voltage, but don't have a status light, it could be a main board problem.
      Your BL_ERR is also slightly above the 1.9V cut-off, so you may have multiple problems. There are ways to force the power supply on, so that you can see if you have a board problem, or a backlight LED problem. That would require some resistors.
      That is a good plan, I just didn't know how long the board would be available at that price, could do that testing to be sure, board will take at least a couple days to arrive, nice to have a spare tho.
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • alegatorul
        sony bravia kdl-43w756c, no power, no sound
        by alegatorul
        the charger brick has 19,2-19,3 vcc
        changed the inverter board same result.
        where should i start?
        cheers
        11-15-2025, 10:00 AM
      • justin35
        Sony bravia kdl-43w755c - boot loop
        by justin35
        i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
        from what i read online it looks to be an emmc issue…
        i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
        i took out the board and say an samsung 16gb emmc
        i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
        i could try to put one instead of the 16gb one, but will it work?
        where do i get the software from?
        any help will be much appreciated!...
        03-06-2024, 12:26 PM
        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
        10-16-2024, 05:15 AM
