Vizio E701i-A3 shutting off
  • TVnovice3
    • Feb 2018
    • 7
    I have a Vizio E701i-A3 that kept shutting itself off after between3 minutes to 3 hours. I thought it was a EEPROM so I replaced the main board and got the same results. So, I replaced the PS and it now works perfectly, has not shut down in a month. I would like to repair the PS if someone can suggest where to start as these intermittent problems can drive one crazy. Thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio E701i-A3 shutting off
    Look for cold solder joints. Re solder all components that are connected to aluminum heat syncs, And re solder all Transformers. Most likely a thermal issue with stressed solder
    • TVnovice3
      • Feb 2018
      • 7
      Will do
      • CapLeaker
        Leaking Member
        • 8190
        also check the terminals where the ribbon cables plug in.
