Vizio E701i-A3 shutting off
  • TVnovice3
    • Feb 2018
    • 7
    I have a Vizio E701i-A3 that kept shutting itself off after between3 minutes to 3 hours. I thought it was a EEPROM so I replaced the main board and got the same results. So, I replaced the PS and it now works perfectly, has not shut down in a month. I would like to repair the PS if someone can suggest where to start as these intermittent problems can drive one crazy. Thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio E701i-A3 shutting off
    Look for cold solder joints. Re solder all components that are connected to aluminum heat syncs, And re solder all Transformers. Most likely a thermal issue with stressed solder
    • TVnovice3
      • Feb 2018
      • 7
      Will do
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        also check the terminals where the ribbon cables plug in.
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Maniackk
          Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
          by Maniackk
          I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
          The cooling system has been cleaned, thermal...
          09-03-2025, 09:32 AM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
