Panasonic TC-P65GT50 8 LED blink failure
  • brent01
    • Feb 2018
    • 7
    As the title indicates, I own a Panasonic TC-P65GT50 that just started experiencing an 8 LED blink failure mode.
    I have performed initial troubleshooting.
    1. When I remove the connection between the SS board and A board the TV powers fine with no flashing LEDs.
    2. I checked the continuity on the plasma panel and the SS/SS2 boards and the resistance between pin 1 and pin 2 on all the connectors ~ 0.3 ohms.
    3. I removed the SS board and have inspected and have not found any visual issues.
    4. I found D051, D052, D053, D041, D042 are shorted. The markings on the top of the package say RFUH20/NS35/1234AW/008. I am wondering if it is worth ordering these ICs and replacing them or would you just order a new SS board?
    SS board = TNPA5648 and not having much luck finding a replacement since the TV is 6 years old.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P65GT50 8 LED blink failure
    How did you check these? Was it the tab to one of the legs or across the legs?
    • tw2005
      • Oct 2011
      • 6458
      • brent01
        • Feb 2018
        • 7
        It was across the legs....pin1 to pin3.
        • tw2005
          • Oct 2011
          • 6458
          go back and do it tab to leg, leg to leg will always be short on these. You can clearly see the legs of 051-053 are all soldered to one solid piece of copper track. And the same applies to 041,042
          • tw2005
            • Oct 2011
            • 6458
            Q101 , 103 are either shorted?(RCJ300N20)
            • brent01
              • Feb 2018
              • 7
              I just checked the datasheet for RFUH20 diodes and the legs are tied together. The leg-to-tab connections are not shorted on the diodes.
              Q101 ~25M between leg and tab, ~46.7k between legs.
              Q102 ~ 500k between leg and tab, ~46.7k between legs.
              Do you happen to have a schematic for this board?
              • tw2005
                • Oct 2011
                • 6458
                no, but you could try a download of the TC-P60GT50 which would do for the most part. don't be surprised if you can't enlarge it claerly.
                So you've checked all transistors on this and none shorted?
                It would appear these boards are around.
                https://encompass.com/item/9555994/P...YUUPS/Pc_Board
                I'd be tempted to get this one and add the capacitor if you are really stuck.
                http://www.shopjimmy.com/panasonic-t...u-ss-board.htm
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                  After all of...
                  07-13-2024, 08:14 PM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
