17IPS20 variant interchangability
+ More Options
Posts
  • vatovey
    • Feb 2018
    Morning all,
    I have a Techwood 4K 55AO2USB unit, naturally it has Vestel components inside.
    I may need to replace the power board in the coming days/weeks due to a progressive fault which seems to be getting worse over time.
    The 17IPS20 variant I have in the above TV has a barcode of 23270172, in addition to another series of numbers/letter located by the connector which connects the power board to the logic/main board of the set, 071114 R9
    I am struggling to find a direct replacement using the 23 number, but am able to find quite a few using the 07 number - and they look identical at component level according to the pictures I've seen.
    Unfortunately, the 07 replacement boards which I am able to source don't have the same 23 barcode number as my board.
    Which is more important, the 23 number, or the 07 number ?, are these IPS20 board interchangeable at all ?
    Apologies for the dumb question, am pretty sure this is common knowledge in this community, I did do a search on this, but couldn't find much relating to it.
  • Rickig
    • Mar 2015
    • 112
    • England
    Re: 17IPS20 variant interchangability
    I would also like to know the answer to this as I need one too
    • armoured_smiler
      • Sep 2008
      • 13
      I believe the 07 is a red herring as it is just printed on at PCB board manufacturer and the 23270172 is the important bit (number of led strings/3v3 stuff etc
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
