JVC AV-28F3SJ-BF Replacement capacitor
  • Ady2017
    • Dec 2017
    • 50
    Hi all
    Quick question. My old trusty CRT TV has got a bad cap. The original is 2200uF 6.3V and following a trip to my pretty useless local electronics shop, the closest match they had was a 2200uF 35V. It was cheap so I picked it up anyway.
    I know you can fit ones of a slightly higher voltage but is 6.3V to 35V a bit too far and unsuitable?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Replacement capacitor
    The increase in voltage rating, of itself, is not a problem. But whether it is suitable (assuming it fits) depends on what the function of the capacitor is. If it's handling substantial ripple (AC) current the 35V part is likely to have a higher impedance and cause stability or noise problems or run hot and not last very long.
    PeteS in CA
    • Ady2017
      • Dec 2017
      • 50
      Thanks for your reply. I decided not to use the 35V part but searched around and found the right part on an old power supply. After swapping it over the TV still had the same problem so although the cap was slightly bulged it was obviously ok. I am learning as I am going. Next step I need a more reliable way to test capacitors instead of putting a multimeter across them seeing if the resistance slowly rises.
      • R_J
        • 9588
        Maybe tell us the make, model and problem and we could help you.
        • vinceroger69
          • Mar 2012
          • 6714
          maybe one of these testers they test the esr etc of the capacitors too
          https://www.ebay.co.uk/itm/Tester-GM...4AAOSwSypZAAVO
          • Ady2017
            • Dec 2017
            • 50
            Hi
            Yes, the TV is a 28" JVC CRT TV. When you first switch it on, you get half the picture as a horizontal band and then after a few mins you just get single red/blue/green lines in the middle of the screen. After about 20 mins the picture come right and can stop on all night and run perfect. I have done some reading and I think it must be the vertical IC chip which is not working when cold. I have resoldered all the joints to the chip and have tried replacing a couple of capacitors anyway without any luck. I am a beginner at electronics repair but it makes sense. The IC chips are obsolete now from what I can see so I guess it is time for a new TV.
            • vinceroger69
              • Mar 2012
              • 6714
              whats the ic part number? capacitors can look good but still be failed with low uf ratings or high esr as a test you can heat the area up with a hair dryer for a couple of minutes does the set then show a good picture?
              • R_J
                • 9588
                more likely its the screen bypass cap. something like 10-22 uf at 250 volts, near the flyback, or bad cap in the vertical output section.
                Like I said post the MODEL NUMBER, should be AV-28????
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Replace ALL the e-caps in the Vertical section (16V, 25V, 50V, etc). Re-flow the Vertical output IC pins and any suspicious cold solder joints in the Vertical section (be careful not to short out any connections). Look for Hi-Voltage e-caps. i.e. 160V, 250V (Not the main filter cap, as that is OK) and replace them, as well. There would be a 10uF 250V e-cap either on the CRT neck board or near the F/back Transformer in the middle-rear in the Horizontal section that may stand out. BTW the 2200uF 35V e-cap will work.
                  • Ady2017
                    • Dec 2017
                    • 50
                    Hi all
                    The model number of the TV is, AV-28F3SJ-BF.
                    I checked as many of the capacitors as I could with the Ohm setting of a multi-meter but as you say, I need to invest in a ESR meter to properly test them. When warm, the TV will work fine for hours on end and I often leave it on all night for the background noise. I did re-flow the solder on the connections to the IC but maybe they needed the solder completely removing and new applying.
                    This has been quite a learning experience but there is something about CRT TV's, they seem more like real TV's what I have grown up with. I even still remember when I way young, my dad had a big box of valves in the shed for the TV and used to have to swap the things when it stopped working.
                    Thanks again.
                    • R_J
                      • 9588
                      Try replacing C801 10uf/250v and maybe C905 10uf/250v (on the crt neck board)
                      • Ady2017
                        • Dec 2017
                        • 50
                        Thanks for this. It doesn't look like something the local electronics store (Maplins) keeps so I will order a couple and give them a try and will let you know.
                        • Ady2017
                          • Dec 2017
                          • 50
                          I have just replaced the 2 10uf/250v caps in the telly. One was C627 on the mainboard and the other C902 on the crt neck board. It has made no difference and the problem still persists. It must be the vertical IC chip, TDA8359J.
                          There is also something else on the main board that I do not recognise but looks like it has been getting hot as the board is quite discoloured around it and it is not connected to a heat sink. There must be 15-20 legs on the component.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            https://www.ebay.co.uk/itm/TDA8359J-...sAAOSwMl9aXhue
                            for capacitors you can open a account with rs components they are very cheap and have free delivery and no minimum order offers but if you want too use ebay this seller sells genuine Panasonic capacitors at a reasonable price as maplin ones wont last very long as only general purpose capacitors
                            https://www.ebay.co.uk/itm/Panasonic...pFYC0lUmNtpYdg
                            • R_J
                              • 9588
                              Have you checked the voltages on the vertical ic, what are they (pin # - voltage)
                              I didn't quite understand the actual problem, I thought the rgb lines were the only problem.
                              You say the picture is compressed top and bottom when it is first turned on?
                              I must not have been using the correct schematic, the vert ic does'nt match in this one. must be a different chassis
                              I also made a typo. It should have read C601, not C801 but that would be to correct lines near the top of screen only.
                              Is there a chassis number somewhere? Is this circuit look right
                              You may have a low +50 volts to the ic, C620 may be badif that is the case.
                              If +14v_vert is low, C625 could be bad
                              • Ady2017
                                • Dec 2017
                                • 50
                                Yes, the picture is compressed when you first turn the TV on and then it goes to just BGB lines and then comes normal. The 2 10uf 250v caps I changed were the only 2 in the TV. It looks like my set is a slightly different revision of the service manual as the vertical IC has a different number of TDA8359J (I hope I have located the right component).
                                Just trying to work out what the other component is. It looks similar to the vertical IC but is bigger and has more legs but it is no connected to a heat sink and there is no means of attaching it to one anyway. It is in close vicinity to the vertical IC so might be something to do with it.
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Now that you have done all that. I would replace the Vertical Output IC. As e-caps and cold solder joints have been replaced and fixed.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    whats the part number of the other ic then we can look at a data sheet
                                    • R_J
                                      • 9588
                                      I uploaded a different pdf, is this one correct?
                                      It is from this manual: https://elektrotanya.com/tv_chassis_.../download.html
                                      • Ady2017
                                        • Dec 2017
                                        • 50
                                        That is the frustrating thing about the other IC. The numbers are worn off of it so I can not find out what it is. I will study the schematics you sent tonight and try and work out what the thing is. What ever it is, it has been getting hot.
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • artvandalai
                                          Where can I get compatible capacitor for replacement?
                                          by artvandalai
                                          Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                                          12-28-2024, 10:15 AM
                                        • r2digital
                                          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                          by r2digital
                                          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                          04-18-2024, 03:50 PM
                                        • rwkish
                                          Discontinued Capacitor looking for Replacement
                                          by rwkish
                                          Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
                                          08-18-2024, 06:54 PM
                                        • Hylax
                                          Replacement capacitor options please?
                                          by Hylax
                                          Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
                                          08-09-2024, 11:25 PM
