DVD player stuck in 'startup'?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: DVD player stuck in 'startup'?
    I'd say it's a 90% chance you have a firmware issue on that. Unless you can find a dump file for your model to flash using a programmer, it's pretty much hosed.
    A working TV? How boring!
    • R_J
      • Jun 2012
      • 9633
      It's hard to tell at this point, a scope would really help to see what the clock and data lines are doing. It is posible the fault is on the dvd player board and it is not communicating with the main micro. Some units look for the presents of the dvd drive, if it doesn't see its there or not functioning it may not even try to turn on.
      If you look at the flow chart on page 22, LED ON? = yes, Is Digitron on normally? = NO, check CD, so maybe its time to check the CD for problems before chucking it.
      • notallbad
        • Oct 2012
        • 1190
        Should there be a constant voltage on RXD0? TXDO & SCK0 both have 4.85v.
        Oddly, on initial power up around 0.5 to 1v comes up on RXD0 but almost immediately drops out. Possibly a response from an interrogation on the Txd0 to shutdown.
        Troubleshooting continues with Section C and D.
        • R_J
          • Jun 2012
          • 9633
          Those are data lines so with out a scope to see if there is any data its hard to say whats going on, when you get into repairs like this, a meter is not going to cut it.
          • notallbad
            • Oct 2012
            • 1190
            I'm aware these are data comms lines and the voltages are of no real significance with a DMM but curious why txd has a constant voltage but rxd line does not, afterall the rxd line at one end will be the txd at the other end.
            • R_J
              • Jun 2012
              • 9633
              all 3 lines have 10k pullup resistors connected to 5 volts, there are also 220p caps to ground on each of those lines, What is the resistance to ground on that line? It could be something is shorted on that line or it could just be the state the ic is in because its not running (no clock)
              • notallbad
                • Oct 2012
                • 1190
                Get a reading of 10.2kohm on that line between P5901 Pin 24 and ground.
                There are some variations between the SM for the Marantz DV3100 and this model, one of them being R583/4 & 8 are 100ohm, not 1.2k.
                • notallbad
                  • Oct 2012
                  • 1190
                  Managed to obtain a replacement DVD laser / tray assembly but the same problem exists so its definately not the laser assembly at fault. So that just leaves the Main Controller board and Power/Interface board.
                  • bogosort
                    Sony DVD player stuck tray (DVP-SR310P)
                    by bogosort
                    I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                    Anyone knows why?
                    Thank you....
                    05-11-2024, 04:29 PM
                  • nervous_capybara
                    Repairing the Hitachi DA-6000 CD player
                    by nervous_capybara
                    Hello everyone !
                    I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                    Feel free to share your experience if you ran into other issues.
                    DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                    CD tray would not come out of the player
                    I could hear a motor spinning inside the player but the CD tray would not come out.
                    Turned out that the issue was the CD tray belt that aged poorly and began to...
                    11-05-2025, 03:11 AM
                  • BMCappelletti
                    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                    by BMCappelletti
                    Hi everyone.
                    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                    02-18-2025, 12:22 PM
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                    MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
                    This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-06-2024, 05:30 PM
