LG plasma PDP50T3, with sound, no picture
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Re: LG plasma PDP50T3, with sound, no picture
    Some additional info:
    Now that I replaced the Y-board and had the good one as reference.. I check again the old Y-board and found out at diode D515 coming right out of the small transformer, there was no voltage. The leg of the transformer generating the 17v had a cold solder joint. Just tried it and the board and TV is working fine
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • SluggerB
      LG Plasma (PDP50R10101) No picture No sound
      by SluggerB
      This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
      So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
      Following a YouTube videos...
      12-03-2022, 09:10 PM
