Samsung UA40H6400AW Is it bad T-Con Panel or Power supply?
  • omnivortex
    • 20
    • Indonesia
    Good day everyone , i need some help with my tv Here's the case my tv suddenly went a little bit dark than before right after i accidentaly update the software at first i suspect it was the update that causing this but after a friend of mine put my mainboard into his H6400 tv with the exact same picture setting as mine and surprisingly the screen are very much bright its not dark at all after that we wonder if its not the mainboard then which part that has a high possibility creating this issue
    What do u guys think? is it the T-con , Psu , or Panel? Thx
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UA40H6400AW Is it bad T-Con Panel or Power supply?
    Backlights
    • omnivortex
      • 20
      • Indonesia
      Originally posted by dskall
      Backlights
      Oh Okay , but i've also read some articles that says as15 gamma ic on T-con can also causing this kind of issue
      • dskall
        • Oct 2016
        • 2905
        • usa
        Do you have picture of problem?
        • omnivortex
          • 20
          • Indonesia
          The picture is normal its just that its not as bright as before , and there's one thing im curious about does software update can change the overall picture characteristic of a Tv? Thx
          • mmartell
            • Oct 2013
            • 3189
            No picture, no advice.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              What we want is a photo of the picture you see on the TV screen. Post this up as soon as you can. Then we would know better what we are dealing with. Thanks.
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
                09-07-2024, 05:50 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
