Missing part of screen on a Samsung
  • Semovski
    • 18
    • Bulgaria
    Hi all
    I have a problem with the Samsung TV. It has a dead horizontal bar on the top of the screen. It looks as 1/5 of the screen is missing. Tried to remove the tcon cable but it didnt change at all. Could it be an issue with the mother board.
    When I removed the cable from the board that is getting in the tcon the line stayed for a minute and then faded
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Missing part of screen on a Samsung
    this looks like a defective LCD panel
    and is not repairable
    as one of the side tabs has failed.
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • Semovski
      • 18
      • Bulgaria
      So it is not possible to be an issue with the main board that doesnt give information somehow where to visualise the picture? I lifted the panel from the led backlight and this part seemed to be transperant where the rest was showing the snow flickles
        It is not a main board fault.
        Almost certainly a panel fault.
        LCD works by transparent pixels appearing white, that's how brightness is modulated from the LED backlight.
        • Semovski
          • 18
          • Bulgaria
          Is there a way to fix it without replacing it?
          How could this possibly happen?
            Not repairable in most instances when it's this type of failure.
            Why does it happen? Because Samsung cheap out on their panels - pieces of crap!!
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Do you think they're as bad as Sharp??? I'm more scared of Sharp right now, LOL.
              And hopefully, my Samsung PC monitor on one of my PCs, aren't shitty like that!
              I noticed that TVs are more likely to take a shit than ad-hoc computer monitors! Why?
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • freakaftr8
                • Oct 2012
                • 3743
                If it has side gate drivers or side tab drivers you could look to see it either side is melted and try pressing on each side
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Those distinct lines right underneath the white spot are a tell tale sign that the side drivers have failed on one side
                    Samsung are distinctly worse.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      I strongly suspected that with their TVs...
                      Arc A770 16 GB
                      • FreakyMex
                        Trouble to identify part (Lunii screen) for replacement
                        by FreakyMex
                        Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                        I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                        02-17-2025, 01:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
                      • JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                        by JunkmanJimbo
                        Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                        No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                        Please help. Thanks in advance!
                        08-12-2025, 11:45 AM
                      • Kiberge
                        Samsung LH82QENELGC/EN Help needed - Static line on screen
                        by Kiberge
                        HI guys!
                        I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                        I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                        the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                        This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                        04-22-2024, 11:28 AM
