LG 43LF5900 mainboard failure
  • wangcheung
    • 11
    I have 3 dead 43LF5900's that were taken out during a surge (lightning). All three have the same symptoms where the standby LED is on when plugged in and when the set is turned on the LED blinks three times and then turns off with nothing displayed on the screen.
    I tested voltages on the power supply board and all are as listed on the power supply board silkscreen including the EN after switching the set on.
    I located one mainboard (EBT63838406)and installed in one set and that took care of the issue. Now my problem is that I can't locate any more boards so I would like to possibly repair the main boards. I have electronics experience but I don't have a service manual for the unit and was wondering if anyone has a service manual for this unit or schematic?
    Thanks in advance,
    Dan
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 43LF5900 mainboard failure
    EEPROM may have failed. Do you have any voltage on DRV_ON when power is pressed?
    • wangcheung
      • 11
      I only get PWR_ON (3.3V), no response from DRV_ON when turning on and off the TV. The standby LED works properly when switching from OFF to ON.
      EEPROM or flash?
      Thanks,
      Dan
      • freakaftr8
        • Oct 2012
        • 3743
        Sounds more like eeprom. I believe you can run stand by to DRV_ON and get backlights.
        • wangcheung
          • 11
          I ordered some EEproms that I think are equivalent. I'll try and replace it on one of the board since I read that a blank will get programmed automagically nothing to lose here
          • wangcheung
            • 11
            I swapped out the EEPROM without any change in function. Guess I'll keep looking for a point of failure.
            Thanks for the suggestion
            • RDC55
              • Dec 2017
              • 180
              "I'll try and replace it on one of the boards since I read that a blank will get programmed automatically"
              And where did you read that? I know it would be possible if the EEPROM's contents were stored in another location such as NVRAM, but it would be nice to have someone confirm how that operation would work and if that is actually true.
              • will62
                • Dec 2016
                • 229
                • usa
                Here's a service manual for the 55LF5950. The main boards look the same, possibly just different eeprom data for the panels. It might help you check voltages on the main board, and verify that the esd/tvs protection on your inputs have not shorted to ground.
                http://service.minjja.lt/files/?id=2944
                • wangcheung
                  • 11
                  Thanks for that Will. I'll check through the service manual now.
                  • wangcheung
                    • 11
                    Hi RDC55, I was skeptical as well. I read in a post on here somewhere that the EEPROM can be updated if blank from ROM but not if corrupt. I was reaching in the attempt and since I have 3 dead main boards I figured I could sacrifice 1. EEproms are cheap.
                    I had 3 identical TVs that had the same symptoms, bought 2 main boards that brought 2 to life but can't find a third main board so I'm trying to debug the board now.
                    thanks
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      I know there are some Samsung TVs that work this way with the EEPROM being rewritten by the NAND. Not heard of any LGs working this way.
                      Why not use an external programmer and read from a working EEPROM and write to another before soldering on.
                      • wangcheung
                        • 11
                        ok, all hopes of repair are lost
                        I was checking all of the power regulator circuits and found that the 1.2V_MTK output was 0 volts when the POWER_ON was present and then realized that the main IC was getting really hot so it appears the main IC is internally shorted.
                        Thanks again for the service manual Will, that made all the difference having the schematics available. Come to find out the schematic matched for the 43LF5900
                        I'll keep my eye out for one more main board. Thanks for the tips and helpful discussion.
                        • wangcheung
                          • 11
                          something I forgot to mention, while reviewing the schematic for the main board I noticed that ALL surge protection components were labeled OPT which I assume to mean optional because NONE of them were populated on the board. I'm not surprised that all three sets failed at the same time. I'm not sure if this is common practice but I would be hesitant to purchase any LG product seeing that cost cutting has left the main components relatively unprotected to save minimal cost. I guess producing landfill is the latest direction for consumer electronics companies. I was very disappointed to to see that. **end of rant **
                          • RDC55
                            • Dec 2017
                            • 180
                            Really some good information knowing that with a "dead" processor all appears normal except for DRV_ON. It would be interesting to know the logic behind that and why the PWR_ON command even occurs.
                            Interesting you lost three TV's in one event. Did anything else in the house get wiped out? Were they all connected to cable / satellite boxes or antenna and powered with surge protectors?
                            "I'm not sure if this is common practice but I would be hesitant to purchase any LG product seeing that cost cutting has left the main components relatively unprotected to save minimal cost."
                            I would suspect all manufacturers are following the same pattern. It's amazing that one chip now handles all the decoding for HDMI, SCART, LAN, USB, etc. I guess we are happy when we go to purchase a new set, but also bummed that they are increasingly becoming a throw away item.
                            • wangcheung
                              • 11
                              There is a separate smaller processor that manages the IR functions and power switch and then hands off after the initial power on.
                              several other devices were lost during the same event, a couple Visio LCD TVs survived though. All were lost through connection to the mains. Surge suppressors weren't able to protect much since this was a lightning strike, although not direct to my house.
                              it disappoints me that we have become a landfill generation, well not those of us that try and repair equipment, but the norm is to discard.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Do you have back lights if you jump to DRV on? Remove Drv on pin from mainboard first.
                                I know I told you to jump this pin but I never got a response to as if you are back lights have come on or not
                                • wangcheung
                                  • 11
                                  update - all three sets were returned to working order by replacing the main board (~50$ each).
                                  • npielawski
                                    MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                    by npielawski
                                    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                    10-15-2025, 01:53 AM
                                  • CDNBrewer
                                    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                    by CDNBrewer
                                    Hello Everyone,
                                    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                    Symptoms:
                                    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                    • I swapped the Left and Right surround
                                    08-05-2025, 09:29 PM
                                  • C152Heavy
                                    by C152Heavy
                                    Summary for TL-DR readers:
                                    • VCC pin (18) of PFC...
                                    01-11-2023, 02:53 PM
                                  • Mirenia
                                    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                    by Mirenia
                                    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                    03-30-2025, 06:47 AM
                                  • orcic
                                    MASTER TL240 and new mainboard LW36BKC01
                                    by orcic
                                    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                    Now I have some doubts about how to connect the new mainboard to the old power supply.
                                    First of...
                                    05-12-2023, 08:10 AM
