Panasonic TX-P42UT30E Recover version?
  • samtron786
    • Aug 2016
    • 170
    • germany
    Hello everybody
    Panasonic TX-P42UT30E gives a Recover version?
    Firmware update abort happened
    Thank you
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panasonic TX-P42UT30E Recover version?
    So did you fix this TV? Was your repair successful??
    • samtron786
      • Aug 2016
      • 170
      • germany
      hi now works again
      • samtron786
        • Aug 2016
        • 170
        • germany
        Software error, 12 flashing red
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Great. Thanks for the information.
          • samtron786
            • Aug 2016
            • 170
            • germany
            Hello, and now 12 red flashes, which means?
            • samtron786
              • Aug 2016
              • 170
              • germany
              nobody can help me?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Main Bd. problem.
                • thslr2020
                  [REQUEST] Modify BIOS version of dumped image(Panasonic CF-RZ6)
                  by thslr2020
                  Hello.
                  I keep tried unlocking FIVR lock(XTU, Throttlestop) to do undervolting, but failed. What I tired is...
                  1. Unlocked hidden menu >>> Disabled CFG lock, Overlock lock, SGX
                  2. Replaced CPU microcode to 2017, 2018 version (pre Spectre, Plundervolt)
                  3. Disabled Intel ME, Hyper-V & Vt-d
                  4. Removed microcode update of Windows(mcupdate_GenuineIntel.dll)
                  5. Try from fresh Win 8.1(boot with USB)
                  Even I already did all of above, XTU and Throttlestop is still locked. So I think what I can do is downgrade the BIOS version, but...
                  06-14-2023, 12:09 AM
                • sikocan
                  Lenovo X1 Carbon 9th Gen Black Screen
                  by sikocan
                  I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                  SN: PF3G1REP
                  MODEL: 20KW-00J1AU
                  PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                  Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                  06-24-2025, 09:01 PM
                  by Vesko356
                  08-11-2023, 03:27 AM
                • TJ65
                  Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                  by TJ65
                  i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                  The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                  I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                  The problem is, that the micom Version doesn't match with the bios version, see picture.
                  How can i update the Micom Version? The Samsung bios update wont work.
                  With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                  01-09-2025, 01:35 PM
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
