LG 32LC56, picture lost after ~20 mins
    It starts normally, then the picture goes off after 15-20 minutes, but the backlight stays on. Sometimes the screen blinks and/or shows garbage first. After a couple of minutes cooling, it works again until warming up. Sometimes the picture comes briefly back.
    PSU capacitors are changed, none of them were bulged but I changed them anyway. Voltages on the mainboard are ok, 5V on the ERR-pin. Only 12V is 11,5V even when the tv works.
    Re: LG 32LC56, picture lost after ~20 mins
    When the picture goes off can you blow cold air onto the circuit boards to try and find which area needs cooling to bring it back to life.
      Cold spray don't affect. I even bypassed the coils L918, the other 902, 903, 904, 905, 906 and 908 are already removed.
      https://www.plcforum.it/f/topic/1028...%A0-in-sandby/
        Do you still have sound when the picture goes off?
          This is weird, it goes on forever when using Scart1. After 1h 45 mins I changed to HDMI1, picture and sound went off immediately. Then I pulled the plug and after short break, TV works normally but only if Scart1 is used.
            If this board uses a separate HDMI codec processor it madly either be bad, or bad voltage to it.
              Check that your HDMI socket(s) is firmly soldered to the circuit board as others have had problems where the metal shield has worked loose.
                I changed C970 on the mainboard, it has worked 3 hours so far.
                https://www.badcaps.net/forum/showthread.php?t=49101
