Samsung UN46C6400 - TV powers on, backlight comes on, buttons work, but no pic.
  • maxvalutech
    • 804
    • australia
    Re: Samsung UN46C6400 - TV powers on, backlight comes on, buttons work, but no pic.
    Yes reasonable that menu etc are OK just not showing. Perhaps try disconnecting one screen lead from t-con and see what happens then reconnect and disconnect the other for a trial. There are gamma voltages tests you can do as well to check tcon board chip.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • ohren
      by ohren
      09-08-2023, 05:24 PM
    • C152Heavy
      by C152Heavy
      Summary for TL-DR readers:
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
      09-07-2024, 05:50 AM
