F42k20e
+ More Options
Posts
  • Coinhunter
    • Oct 2011
    • 65
    F42k20e
    A friend just gave me this TV and of course I need some assistance with it. All 7 threads about this unit are different from mine as they must have made 15 million different versions with the same model number just different parts. I am fairly certain I have it narrowed down to the audio/video main board as the problem but I am not a guru like you guys and I really appreciate it when you take time to help an old fart. Anyway when turned on it powers up, blue screen comes on looking for source then is go bat crazy. It starts poping and cracking, the screen stays blue but there are lines all over it, then it will clear for a second then back to the crazy stuff over and over. The poping and cracking noise coming through the speakers is really bad and it will not let me turn the volume down. If you folks can help me fix this I plan on giving it to a couple whose old set is on it's last legs. Thanks in advance.
  • maxvalutech
    • 804
    • australia
    Re: F42k20e
    You really need to supply the various voltages you read firstly from PSU to ensure its operating OK then the main board check of voltage regulators etc. Is the set tuned in, is the antenna connected ?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Re: F42k20e
      The voltages are given in the red box and should match what you read on the pins of XP901
      • Coinhunter
        • Oct 2011
        • 65
        Re: F42k20e
        I just measured the voltages Dick and noticed I had posted an incorrect picture. Here is the correct board with the vo;tages and connector marked in red like yours. Thanks Ralph
          Re: F42k20e
          https://www.badcaps.net/forum/attach...5&d=1515606978
          I do not see the Voltage readings for the STB (PS-ON), SW (BL-ON), and BRI (Dimming).
          • Coinhunter
            • Oct 2011
            • 65
            Re: F42k20e
            Okay 3rd. try my bad, just don't believe I think it through completely that is why I asked for help. Thanks for being patient with me. Seriously now I believe I have everything in the picture measured and I remembered to plug it in connect the power and main boards and turn it on LOL Major voltage changes on a couple in my thinking (maybe not to you guys). From looking at other boards the voltages for stb, sw, and brt/dim seem to be relatively correct. I updated the photo to show changes. Thanks
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Re: F42k20e
              There are at least two voltage regulators on the mainboard. What are the voltages on the 3 pins of each.
              • Coinhunter
                • Oct 2011
                • 65
                Re: F42k20e
                Measurements for the 2 voltage regulators showing all 4 legs relative to position on board with chip id
                • Coinhunter
                  • Oct 2011
                  • 65
                  Re: F42k20e
                  Totally repaired guys, thanks for the help.
                  • marce002
                    Macbook Core i7 2010 a1286 820 - 2850A CRAZY JUMPING voltages
                    by marce002
                    Hello
                    Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
                    CRAZY JUMPING
                    PP3V3_S5 = 0v to 3.33 v jumping
                    PPBUS_G3H = 12.4v to 12.48 jumping a little
                    PP5V_S5 = 2v to 5v aprox, jumping fast
                    P3V3S5_ENTRIP = crazy jumping from low volt
                    SMC_PM_G2_EN = jumping 0v to 3.3v crazy
                    STEADY
                    P3V42_G3H=3.39V steady
                    PP5V1_CHGR_VDD=5.06v steady
                    PPCHGR_DCIN= 18.29 to 18.31 jumping
                    09-08-2021, 04:08 PM
                  • sda sad
                    my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                    by sda sad
                    Hope this is the right place, someone can help me.
                    My laptop started having a really strange problem....
                    When I turn it on the fans start working at a crazy rate and with random breaks...
                    They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                    And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                    The model of the computer:
                    Xiaomi Notebook Pro X 15 OLED (A30)
                    04-23-2024, 09:55 AM
                  • paparazzo79
                    Lenovo Tab 2 Pro display "going crazy"
                    by paparazzo79
                    Hi guys
                    I got myself Lenovo TAB 2 Pro at Friday.
                    I did used it whole Friday just to test it and it was working normally.
                    I installed few apps and charged it via regular USB 3.0 port on my laptop.
                    After that I noticed that tablet behaves like it has a virus.
                    Suddenly it just registers touch input, byitself starts to exit from tabs,volumes up or down,freezes,when press home key does not register etc etc..
                    I remember I did cleaned it yesterday with isopropyl but I put the alchocol on dry cloth and cleaned the screen and metal housing...
                    really few...
                    02-26-2023, 12:31 AM
                  • Baldrick
                    Samsung UN48H6350 - Going Crazy
                    by Baldrick
                    Hi all. I've got a Samsung UN48H6350 that suddenly started going crazy.
                    The volume goes all the way up then down, inputs keep changing, it turns on and off. It's constant too. I unplugged all inputs from it thinking it might be a CEC issue with no luck. Unplugged it overnight with no change.
                    I did read something that said this is fairly common with some Samsungs. If this is a board swap, I was wondering if anyone knew about this issue and could tell me what board needs replacing.
                    Thanks!
                    11-27-2021, 10:01 AM
                  • John Jenson
                    Crazy Laptop problem - HP Envy x360
                    by John Jenson
                    This laptop model is HP ENVY x360 Laptop - 15m-ed0013dx (9HP23UA)
                    It died one day and wouldn't start, all lights out. The charging light on the side is out with charger plugged in (tested output, good charger).
                    I took the cover off and disconnected the internal battery and reconnected it. After doing so, I could start the computer up to a blue BIOS screen about BIOS being corrupt (from disconnecting the battery I presume) and after hitting enter, back into windows; everything working. The charging light will light if I plug in the charger (red while charging/whitish...
                    05-03-2023, 09:17 AM
