Lenovo Tab 2 Pro display "going crazy"
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys
    I got myself Lenovo TAB 2 Pro at Friday.
    I did used it whole Friday just to test it and it was working normally.
    I installed few apps and charged it via regular USB 3.0 port on my laptop.
    After that I noticed that tablet behaves like it has a virus.
    Suddenly it just registers touch input, byitself starts to exit from tabs,volumes up or down,freezes,when press home key does not register etc etc..
    I remember I did cleaned it yesterday with isopropyl but I put the alchocol on dry cloth and cleaned the screen and metal housing...
    really few drops of isopropyl on wet cloth and then over tablet..
    So I am now confused if I screwed up the tablet pro probably I got it like this.
    What could cause such an issue?
    The only way when tablet goes crazy is to stop this, is to press power button and press back.
    I also notice that power button is a bit loose.
    The issue also happens like when I watch the yt video it suddenly displays volume icon on screen,but I am not touching any part of tablet.
    It justs registers touch inputs without my interraction.
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Re: Lenovo Tab 2 Pro display "going crazy"
    Damn...it was a little piece of hair on the screen...I hope that is it, I am now monitoring the work of a tablet without it...
    • diif
      • Feb 2014
      • 6978
      • England
      Don't use alcohol on the screen you will damage it.
      • paparazzo79
        • Dec 2018
        • 303
        • Bosnia
        Damn...I already did yesterday..
        So what did I do? :'(
        • diif
          • Feb 2014
          • 6978
          • England
          Once is ok but long term can damage the coating on it.
          • paparazzo79
            • Dec 2018
            • 303
            • Bosnia
            Oh okay I did not know that.
            I thought most of glass cleaners for screen are based on some sort of alchohol.
            I am charging the tablet now and will see how it will behave, if again goes crazy will try to record so you guys see.
            I hope it was a piece of hair only making contact.
            I used isopropyl on Surface tablets, too.
            I can't get special glass cleaners for tablets here.
            Maybe then just use dry cloth,huh?
            • paparazzo79
              • Dec 2018
              • 303
              • Bosnia
              Here is the link on what is happening:
              https://youtu.be/OoJrL1ijdh0
              • paparazzo79
                • Dec 2018
                • 303
                • Bosnia
                A some guy told me it is called ghost touch due to bad digitizer.
                • paparazzo79
                  • Dec 2018
                  • 303
                  • Bosnia
                  Okay so at the back side of tablet I read input:12V 1.8A.
                  And I used 5.2 V and 2A charger but it is all my fault and seller supplied me with that charger.
                  Could I potentially damage the tablet with 5V charger or the screen is damaged with etyl alchohol?
                  I mean I only used few drops on towell and wiped the screen when it was off with the towel.
