55" Samsung curved screen removal tips?
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Got me a 55" samsung with one LED bank being intermittent. Or top of screen is flashing on off I should say suspecting LEDs,not sure if it's edge lit or not.
    Any of you have experience with removing the panel without breaking it instantly? Looking for some tips/hints.
    Was thinking of getting a bunch of small suction cups and a vacuum pump and make a rig that holds the cups rigged to the panel.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
  • freakaftr8
    • Oct 2012
    • 3743
    Re: 55" Samsung curved screen removal tips?
    Never removed a curved screen yet. I would imagine is just a flat LCD panel pushed in by the frame. Honestly that would scare the hell out of me removing one too. I would imagine after removing the plastic bezel there would be some kind of a mounting system holding the LCD to the metal back frame or chassis
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Curved screen TVs have to be worked on in the upright position. However, removing the screen would be a bit tricky. Never lay it on the front. Lie it down on the back and eight small suction cups, 4 at the top and 4 at the bottom. Run a sturdy string through the cup handles and with a pole (I use broom sticks), carefully lift with a friend's help and rest the poles on a specially designed stand on a safe area.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        So two poles,one above a set of 4 cups,strings up from each cup to pole,each person handles a pole? Am I picturing that correctly?
        • lfhlaw
          • Mar 2014
          • 115
          So How flimsy are the Curved screens? I mean a typical LCD screen is somewhat flimsy and I've moved those by myself without much of a problem? are the "Curved Screens" just a flat LCD that are more flexible or are they just rigid?
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
