Toshiba Regza 32AV635D LCD vertical lines
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Hello everyone and Happy New Year!
    First problem of the set was the PSU went dead after a power surge. Toshiba service center says that new PSU will cost too much and the owner bring it to me(we have a common friend). I order from Ebay(trustworthy seller) a exactly the same replacement PSU board(SRV2169WW-I) and now tv is powering on as it should be. BUT..
    Second problem is the image on LCD. The only thing that appears is a faint square with two vertical lines at the center.
    So i wondering..
    1)New psu has a problem(small chance for that)
    2)TCON board went off as well
    3)Tab bonds screwed from the transportation
    4)Main board problem
    From your experience, what is the most possible cause?
    Thanks for your time
  • jbfr_54
    • Dec 2012
    • 52
    • France
    Re: Toshiba Regza 32AV635D LCD vertical lines
    I would try to clean and reset all flat ribbon cables from Tcon to panel and LVDS cable too (from Main board to Tcon). If not satisfying, small chance for the Tcon failing, more probably a panel tab bonds failure. Good luck
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      its more than likely a bad t-con as it gets its power from the PSU and when the PSU went out it could have taken the t-con
      let us know what happens after cleaning the flat flex cables and the LVDS cable
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • Nightwalker
        • Oct 2012
        • 76
        • Greece
        Thank you both for replies
        Forgot to mention that, was the first thing i tried, cleaning both of them with IPA, apply gentle pressure to LVDS and TCON connectors and ribbons, even on timing ic of TCON to see if something change, with negative results.
        @jbfr_54 My concern is that when i open menu, nothing change on screen, on other lcds i had repair with tab bonding problems, when menu key is pressed, you see a change in colors or shapes.
        I am not sure if same pattern exist on all tabs bonding problems ;/
        @jasonr2000 I'll check tomorrow if 12v voltage goes to TCON is the same line of the 12v output of PSU. Must be the same, i guess, but resistance on both psu's at 12V line is the same.
        Im planning to take some basic measurements on TCON board (filters/fuses, voltages etc) and if nothing is the answer, i have already inform the onwer, and agreed, to go for a TCON replacement. If even after that, problem is still there, next step is panel disassembly to check the tabs. I hope MAIN board to be ok..
        Any other thoughts and ideas are welcomed
        Also schematic attached
        • Nightwalker
          • Oct 2012
          • 76
          • Greece
          Hello again
          Just receive the Tcon replacement board, problem is exactly the same..
          So not a Tcon problem..panel or mainbord left for checking..
          Connecting an external RCA source, sound is ok, image appears 100% correct only 1cm on the top of lcd, rest of the area has problem..
          As you can see from the pictures..any ideas to isolate the problem?
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • oxi1158
            Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
            by oxi1158
            My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
            I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
            10-09-2020, 08:37 PM
            09-06-2024, 05:27 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
            09-06-2024, 05:59 AM
