Red, Green, Blue, Gray Cycling problem of Acer LCD
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    i have a Casper 19CSPR LCD . that is brand name of Acer.
    logic board is 715g2904-1.
    first problem is 2 second to black. One CCFL doesn't work. inverter is O.K.
    second problem is there are red, green, blue, gray horizontal thick line at pic this 2 second.
    i tried other lcd panel with this power and logic board with success. pic is fine. no problem.
    and i use another philips board with patient lcd panel .problem remains..
    but this time form of problem is changed. red, green, blue, gray flashing cycle.
    and another problem occur.
    neighbour of bad CCFL also gone when i try with original psu.
    sometimes i feel strange smelling.
    everbody say red, blue cycling is due to EEPROM.
    Factory reset solves problem... i don't know this board's button for it.
    and this is weird if i change the panel... problem goes.
    what must i do except changing CCFL's?
    Re: Red, Green, Blue, Gray Cycling problem of Acer LCD
    I have had a red-green-blue-white cycling problem before on my iiyama monitor.
    https://www.badcaps.net/forum/showth...ghlight=iiyama
    I fixed it by finding a sequence of keys to press. Maybe it's similar to your Acer monitor. Most of these Chinese monitors are made by only a few manufacturers.
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • high-tech
      Samsung UN55F7050AFXZA ver. TD01 power cycling
      by high-tech
      Hello everybody, I could use some help on this one... It's got me guessing...
      I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
      (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
      (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
      (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
      (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
      9. ground (PWM2) 10. 0.9 volts cycling...
      09-15-2020, 03:39 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • kity92
      Edifier x3 Earbuds Blue Light Problem (Charging Problem)
      by kity92
      I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
      Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
      01-13-2022, 01:49 PM
    • usbdevice
      Acer X223HQ (Version Bbd) on/off-power-cycling
      by usbdevice
      Hi all
      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
      https://www.badcaps.net/forum/showthread.php?t=50657
      https://www.badcaps.net/forum/showthread.php?t=40512
      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
      It's my dad's old monitor. He...
      08-05-2022, 02:21 AM
