Soniq Smart TV, No Backlight.
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Soniq Smart TV, No Backlight.
    maybe these? you may have too measure the length of the strips used in your tv as i see these alter
    https://www.ebay.com/itm/2-Pieces-lo...-/201707956443
    https://www.ebay.com/itm/2-Pieces-lo...75.c100623.m-1
    this video gives you a rough idea on how a edge lit tv is striped down to replace the leds/strips
    https://www.youtube.com/watch?v=EZypCE6slYo
    • redrooster
      • May 2011
      • 114
      Those strips look like they'll fit OK, they are Samsung 40 inch edge lit so I'll take the display apart and measure them although I'm confident they'll be good for the job.The YouTube video was great too, I learned a bit from that! Thanks heaps for taking the trouble to help me with this fellas, it's appreciated.
      HP P6-2203a desktop,AMD CPU A8-5500 with Radeon HD7560D,3.20Ghz. Radeon HD 6670.8Gb Ram.2TB HDD. WIN 10 64 bit O/S.
      • genuineguy
        • Sep 2015
        • 46
        • india
        Hello
        I have been searching for some voltage references for this LED driver too.
        What is the significance of 1.6V on CN2 labelled as V_sync ? It connects from the LED driver into the samsung panel TCON board of my 40PFL4707
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
          09-12-2024, 02:30 PM
          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
