LG 32LN530B-UA Randomly shuts off
  • shadetreetrader11
    • Oct 2015
    • 230
    I have a LG 32LN530B-ua that after about 10 min or so it will just randomly shut off. Took the psb out and looked for any solder connections that have gone bad. Nothing, No bulged caps. I messured them with ESR meter and everything seems ok. Took a heat gun and warmed up different components and also used freeze spray with no affect. I also went into the settings and changed the powersave mode from automatic to off. So at this point I'm lost. All the voltages going from the psb to the main board are good. Anyone have any ideas?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG 32LN530B-UA Randomly shuts off
    Does it shut down or just lose picture? You can monitor ps_on. Have you tried heating main board. What is the dc voltage on main capacitor when on?
    • shadetreetrader11
      • Oct 2015
      • 230
      I have tried heating up parts on the main board as well. Have tried lightly tapping on components on both main board and PSB board with a small plastic tool. Have tried to clean all the connections from board to board. Can't make it fail. The voltage on the main caps with power off is 169.5. And with power on it varies from 161-164.4.
      • shadetreetrader11
        • Oct 2015
        • 230
        And it does shut off. I have to hit the power button again to turn it back on.
        • dskall
          • Oct 2016
          • 2905
          • usa
          What is voltage printed on main cap?
          • shadetreetrader11
            • Oct 2015
            • 230
            450 volt
            I also unplugged the wire going to the control board? ( Pwr, vol, channel, menu) . I'm took the batteries out of the remote also. I'm probably reaching a little.
            Last edited by shadetreetrader11; 01-01-2018, 12:49 PM. Reason: Forgot to mention the remote
            • shadetreetrader11
              • Oct 2015
              • 230
              • dskall
                • Oct 2016
                • 2905
                • usa
                With tv on you should be getting around 390dcv on main cap. Seems to be something wrong with pfc on power supply.
                • R_J
                  • 9540
                  once the tv is turned on, unplug the cable that goes between the buttons and the main board, I suspect the power button tac switch could be the cause.
                  • shadetreetrader11
                    • Oct 2015
                    • 230
                    Originally posted by shadetreetrader11
                    450 volt
                    I said control board. I should have probably said buttons instead.
                    • R_J
                      • 9540
                      I missed that. I see you also tried tapping the boards, have you removed the power board and looked at the solder connections on the larger components like the transformers, coils and the ones attached to the heatsinks?
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        I did inspect all the solder connections and they really look good.
                        One thing I was wondering about is the back lights. Is there a way to see if one of the backlights are randomly faulting.
                        And also the 390vdc that dskall was talking about.
                        • R_J
                          • 9540
                          The power supply does not have a pfc circut, so 170 volts dc is fine. Its a universal input 100-240 volt ac input.
                          If the backlights went out, then usually, but not always, you would still have sound
                          Try unpluging the backlights from the power supply and see if the tv comes on. If it comes on and you have sound (no pic without BL) then I doubt thats the problem
                          Shopjimmy does offer an eeprom for this model, maybe thats the problem, but if the eeprom is bad the tv usually won't turn on
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            I unplugged the back light and the video and audio where still there. So your right about that.
                            • R_J
                              • 9540
                              I would suspect something on the main board is the cause, (bad bga ic) also if you have something using the hdmi plug, remove that as a possible source of the shutting down.
                              • shadetreetrader11
                                • Oct 2015
                                • 230
                                Is that bga ic a form of an eprom? I took the power supply board off and took kind of a shotgun approach and retouched up ALL the solder joints and it didn't change anything. It still turns randomly shuts off.
                                • R_J
                                  • 9540
                                  No the eeprom is IC1300, the bga type would be IC1201 and IC101
                                  • shadetreetrader11
                                    • Oct 2015
                                    • 230
                                    Little 32" TV isn't worth what they want for a used main board. Wish I knew what ic it was that is faulty. Would probably be pretty hard to figure it out because it's so random. Maybe I'll find the same TV with a cracked screen and I can use it for parts. Thanks for your help guys.
                                    • shadetreetrader11
                                      • Oct 2015
                                      • 230
                                      Replaced the main board now the image is upside down. GRRR!!!!
                                      • shadetreetrader11
                                        • Oct 2015
                                        • 230
                                        Mirrored the screen and now it seems to work good. Ended up buying a service remote to get it done. Thanks for all the help
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • chevellebbc@yahoo.com
                                          Static?? If I hover over the main board it shuts down
                                          by chevellebbc@yahoo.com
                                          Hoping for some newbie help. I had a tv in the basement for years that needed diagnosis. Finally got to looking at it. First was a backlight issue. Power supply checked out and replaced the led set. Then when the main board plugged it the backlights shut off. So pulled the main board tested as many components as possible and didn't find the culprit. So sourced an eBay one for cheap hoping it was something correctable. But now with the timing board unplugged the tv will start with backlights and stay on. However if I touch the ribbon it'll attempt to shut down. Now if I even hover my hand above...
                                          03-18-2023, 09:37 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
