Static?? If I hover over the main board it shuts down
  • chevellebbc@yahoo.com
    • Mar 2023
    Hoping for some newbie help. I had a tv in the basement for years that needed diagnosis. Finally got to looking at it. First was a backlight issue. Power supply checked out and replaced the led set. Then when the main board plugged it the backlights shut off. So pulled the main board tested as many components as possible and didn't find the culprit. So sourced an eBay one for cheap hoping it was something correctable. But now with the timing board unplugged the tv will start with backlights and stay on. However if I touch the ribbon it'll attempt to shut down. Now if I even hover my hand above the main board ribbon it'll also attempt to shut down. Have a video trying to add a shareable link
    • 12328
    • U.S.
    Re: Static?? If I hover over the main board it shuts down
    Lets see a video of that hover shutdown thing, sounds fascinating.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
