Vestel 17PW26-4 No Standby
  • TechWizard.Support
    • Aug 2017
    • 30
    • United Kingdom
    Just some quick background, I'm a computer technician with very basic soldering experience, and I'm looking to learn more about component level repair. I own a multimeter with diode mode & continuity, an ESR meter and an Antex 760RWK Rework station. I have some basic knowledge about electronics.
    My client has a Technika LCD32-229 with a Vestel 17PW26-4 Power Board and there is no standby power. I said that I mainly deal with computers, but I'd take a look and could replace the capacitors if they were the issue. Upon inspection, these looked OK, and just to be sure, I confirmed with my ESR meter.
    The inside of the TV and the board were thick with dust, the vents were completely blocked and I'm guessing some components may have overheated. Once cleaned, I noticed a lot of burn marks on the board, quite extensively around C903, D800, D882/3, Q813 and minor signs around the transformers and various other components. Do you think this board is too extensively damaged? Or is it worth troubleshooting further? I have included images of the front and back of the board and a schematic I found.
    Thank you for taking the time to read my post, your support will be greatly appreciated!
    Richard.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Vestel 17PW26-4 No Standby
    This is whats in the repair kits for no standby faults so maybe start with checking these first
    F800
    Q813
    Q814
    IC830
    D894
    R860
    R8661
    R971
    C840
    FAN7711
      • Aug 2017
      • 30
      • United Kingdom
      Thanks Vince, here are my results:
      F800 - OK
      Q813 - OK, no shorts
      Q814 - OK, no shorts
      D894 - OK
      R860 - 32.8 (33) Ohms
      R861 - 32.8 (33) Ohms - Can't see an 8661, I presume you meant 861
      R971 - 0.26 (0.22) Ohms
      C840 - 30.78 (33) uf, 0.82 Ohms ESR
      IC830 / FAN7711 - Not sure how to test this
      *Expected value in brackets.
      Is it best to remove the MOSFETs and test the switching out of circuit? I just tested for shorts. Excuse my lack of knowledge, this is a new area for me!
      • diif
        • Feb 2014
        • 6978
        • England
        You can give MOSFETs a test in circuit with your meter in diode mode.
        https://www.utm.edu/staff/leeb/mostest.htm
        If they show a short then I remove and test out of circuit.
          • Aug 2017
          • 30
          • United Kingdom
          Thanks for that Diif, I did take a look on that page myself, but didn't test further as there was no short. I bought a replacement board for my clients TV, but I'd still like to work on this board myself as a project to develop my understanding.
          When I get chance in the new year, I'll come back to this board and work my way through it. So any guidance regarding a troubleshooting process to follow would be greatly appreciated. I watched a few videos from MrReeceyburger123 which have been helpful, so I certainly appreciate the time he and others have committed to help people new to the area such as myself.
          • R_J
            • 9623
            If you have no standby voltage I suspect IC806 has failed.
            Check the resistance of R1012, You can also check the fet inside the ic, check the resistance between pins (6,7,8) and ground, if there is a short the ic is bad.
            It could also be as simple as a bad C801 (33/50v) or C892 (10/50v)
              While the set is plugged in you should check the standby voltage on the connectors going to the main board. If unsure just check all voltages and see if anything is active.
                • Aug 2017
                • 30
                • United Kingdom
                Thanks R_J, I'll check that IC806 & R1012. Regarding the caps, they tested ok with my ESR meter.
                Tom, I'm getting nothing on that connector, sorry, I should have mentioned this in my original post.
                  Schematic:
                  Check points:
                  F800: check ok
                  C802, C934: expect ~320V DC across either
                  D879, IC831 (dual diode): check not shorted
                  D823, D884: check not shorted
                  5V/3.3V standby outputs - check each to ground, not shorted
                  C817: check for 12V when set connected to mains
                  C892: Vcc, check for 7~18V when connected to mains
                  C801: Vcc, check as above
                  D807, D862: check not shorted
                  Measure resistance across C892: should be high (>100k)
                  If Vcc is present but oscillating: Replace C892, C801 and D866 (5.1V zener).
                  If Vcc is DEAD and no shorts are visible, OR Vcc line has short, then IC806 is probably bad.
                  • K_i_t_c_h
                    • Nov 2019
                    • England
                    Changed all the faulty capacitors still no joy, found ic806 was faulty replaced and now working TV!!! R1012 and c801 was okay in this repair
                    Original fault for me was turn the power button on and stand by voltage would drop and would loose voltage to the standby and would give me voltage again and turn of again, thanks for this suggestion and taking the time to reapond!!
                    • cruiser_
                      Vestel 17IPS71 + 17MB82S - no standby
                      by cruiser_
                      hello there,
                      I am trying to fix a Walker 40 TV - it has Vestel 17IPS71 3R3 as PSU and 17MB82S for logic.
                      How I got here...
                      The TV had shorted USB connector, which I fixed. TV turned on. Ran for a few hours on HDMI input. Started to see some dark dots/patterns on the screen as seen on the photo.
                      I restored to factory setting. The TV has rebooted only to a blinking standby LED. It sat there for a number of minutes after which I disconnected it.
                      Now, after plugging it back in - there is not even a standby LED.
                      My 17IPS71 provides 12V, no standby...
                      11-25-2021, 12:48 PM
                    • Adenitz
                      Troubleshooting Vestel TV, has standby, but cannot turn ON
                      by Adenitz
                      I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                      Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                      Both boards are shown in the attached photos.
                      What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                      12-27-2023, 03:43 AM
                    • Aivar1988
                      JVC LT65VU83K Vestel 17MB130P no standby light
                      by Aivar1988
                      Hello!
                      Bought a used TV last weekend and everything was fine when I tested it. Back home I tried to connect it with my PC via HDMI. I noticed that the picture didn't quite fit in the TV's picture and so I tried to change the output resolution on my PC and then changed the picture formats on the TV. I still didn't get the picture right and stopped to google the problem and then it happened - the TV died on me after I got to use it for 30min.
                      JVC LT65VU83K Serial nr. 7975101 800044
                      Panel: VESTEL VES650QNTS-2D-U11 Manufactured 18/04 23443739
                      Power board: VESTEL...
                      08-31-2021, 05:47 PM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • ray14324
                      Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                      by ray14324
                      Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                      The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                      Reading into this symptom the general consensus was that...
                      08-31-2021, 07:55 AM
