T-con 6870C-0267A problem help
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    i have that t-con with a problem.
    IC TPS65162TI is going to be very hot. I have already replaced it without success.
    If i put external 12volt on L1 the absorbment is 450mA and ic go to be hot.
    If i remove L2 ic is not more hot. I checked absorbment on L2 circuit and is just 100mA, also i have replaced L2 without success.
    Checked some short capacitor but nothing. Can someone help me?
    Thank you in advance.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: T-con 6870C-0267A problem help
    What is the symptom you are getting that lead you to believe the T-CON is not good?
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      It's present audio with no video
      • dskall
        • Oct 2016
        • 2905
        • usa
        Try freezing components around and see if ant others getting hot
          how about checking the load that is connected to the circuit, may be load is drawing too much current.
          • Pragmatiko
            • Jul 2013
            • 468
            • IT
            Hi Budm, which load I need to isolate? I have removed L2 coil and seen that without L3 ic is not more hot. But if I put external voltage on output of L2 there is just 100mA absorbent.
            • THXFX
              samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
              by THXFX
              Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
              I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
              When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
              What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
              I check capacitors and diodes and didn't find any short IN MAINBOARD.
              Measured all power supply...
              03-20-2024, 03:21 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
