Led samsung remote doesn't work
+ More Options
Posts
  • crdz66
    • Nov 2012
    • 242
    Hi everyone.
    I need your assistance.
    I have a led samsung tv un46f6350afxza with remote control not working.
    I test couple remote control on another samsung tv and working good.
    History.
    This tv was working good until the tv start turn on/off too many times.
    I decide change the main board and the problem was fix it, means now work properly keeping on and wifi working good.
    But, since i change the main board the same remote stop working.
    I already check :
    As soon you press power on you see on ir board the voltage drop from 3.3v to 2.8v.
    The joystick back of the tv working good let me turn on and off.
    What do you think guys?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Led samsung remote doesn't work
    You most likely have a bad IR sensor. Or check the pins that connect that to the main board. Make sure nothing is bent or pins in the ribbon popped out.
    So no remotes work the tv or just the one you have for it? Is it the intelligent touch kind or just a standard IR remote?
    • crdz66
      • Nov 2012
      • 242
      It's not intelligent one.
      I have three samsung remotes on none working on this tv
      • freakaftr8
        • Oct 2012
        • 3743
        That voltage drop doesn't sound right. Test your 3.3 V at main board with IR disconnected and see if that drops as well
        • crdz66
          • Nov 2012
          • 242
          Well back on this tv still the remote doesn't work.
          I wondering if the voltage on main board show .6v (on pin IR) is right or need to be higher.?
          I replace the ir sensor and still doesn't work.
            Cans we see the pictures of both sides of this IR board?
            • crdz66
              • Nov 2012
              • 242
              there you go
                https://www.badcaps.net/forum/attach...3&d=1517782822
                So what is the Voltage as request in post #4?
                  09-07-2024, 05:50 AM
                • Mgiffune
                  by Mgiffune
                  I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                  I ordered a supposedly β€˜new' Tcon board this time, and
                  06-09-2024, 10:28 AM
                • jesterace
                  Samsung B2030HD IR Remote Receiver Dead, shorted micom?
                  by jesterace
                  I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
                  Tried installing latest firmware but no change.
                  TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
                  Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
                  10-26-2022, 02:20 AM
                  09-06-2024, 11:40 PM
