Samsung UE60F6300AKXXU....Dead
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Can you help? Have a Samsung UE60F6300AKXXU that is dead, taken back off and found fuse across mains input connector is blown, now I am sure it is not that simple or is it? only had things in past have the mains fuse blow and replaced it and it blows again as something else is pulling it down.
    Can anyone suggest where to start on this PSU please? I have checked the diode and none of them are shorted.
    Andy
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung UE60F6300AKXXU....Dead
    Check bridge rectifier. Better pictures of power board.
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      Images as requested, can you point me in the direction of the bridge rectifiers please.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Bridge rectifier is component BD8015.
        Using this picture as a reference...
        https://www.badcaps.net/forum/attach...7&d=1513671851
        ... start at the lower left corner, go right just past the center, and then go slightly up. You should see BD8015 board designator right there. It is that 4-pin component with the pins labeled "- ~ ~ +" from top to bottom.
        But really, this is not necessary to do right now. You have a burn mark on your board. Again using this picture as a reference...
        ... look at the heatsink (silver block of metal / radiator) on the right side of that picture: there is black sooth right where the white glue is and where you can see the board designators CP806 and QP802C5. If I had to guess, that's probably one of the APFC MOSFETs that has gone bad. So you will probably need to remove that heatsink in order to get to it.
        Please post a picture of the underside (solder side) of the PSU, if possible.
        • Andyd1970
          • Feb 2013
          • 374
          • united kingdom
          Hi Guys, Sorry for delay. I have removed heatsink and the three MOSFET's do not seem to be blown, the blue cap near the middle one is slightly split and blacken, so is that the fault? or can a MOSFET blow but not actually blow up?
          • vinceroger69
            • Mar 2012
            • 6714
            yes those capacitors can fail like that can you read the printing on the side of it so you can order a new one
              You should check the FETs are not shorted using a meter but those capacitors can and do fail. Samsung sets are somewhat notorious for it, as well.
                Another failed snubber cap, go with 2KV replacement, the body is still intact so you should be able to read the capacitance value.
                • Andyd1970
                  • Feb 2013
                  • 374
                  • united kingdom
                  This looks like a resistor? as it says R 221K 1KV on it?
                  If so I need a 221k that is rated at 1KV? or do I need to look for something else?
                  Thank you
                    It's not a resistor.
                    221 = 220pF. (22 x 10^1)
                    K= tolerance code. In this case 10%
                    Use a 2kV (voltage rating) cap to reduce chance of future failure.
                    So you are looking for 220pF 2kV, tolerance 10% or better
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      https://www.ebay.co.uk/itm/10pF-10nF...QIwCGTItpeZ9BA
                      • Andyd1970
                        • Feb 2013
                        • 374
                        • united kingdom
                        OK, great ordered the caps.
                        Testing the three MOSFETS...is it just as simple as putting meter across two pins and checking for no short circuit? only one of the only has two pins.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          mosfet testing
                          https://www.utm.edu/staff/leeb/mostest.htm
                          the two legged device maybe a diode just test it in both directions
                          • Andyd1970
                            • Feb 2013
                            • 374
                            • united kingdom
                            Hi Guys,
                            Fitted the tiny blue cap as per Tom's attached link from ebay, fitted it and replaced the 5.0A fuse on PSU and the TV now powers up OK
                            I guess that means it is fixed? but will test it for a few hours.
                            Thank you everyone for you help.
                            • Andyd1970
                              • Feb 2013
                              • 374
                              • united kingdom
                              One quick question...
                              The fuse I just used a 5A 20MM quick blow fuse from Maplin and soldered wires to it and insulated the fuse in heat shrink as could not find the type soldered to the PSU, does it matter that I do not use the type that was fitted?
                              Sorry for all the questions.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                As long as the fuse is of the same current rating, type (slow blow or quick-acting), and voltage rating (or higher), the rest shouldn't matter.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  as your power supply has the T before the amp marking it is a fast blow so you should be fine may also be worth adding some new heatsink compound on the mosfets/diode when you re assemble the heat sink as will save possible future overheating issues etc
                                    T is time delay, F is fast blow. Use time delay.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      sorry i did read the page wrong now re reading it tom66 is right time delay
                                      quote
                                      Read the manufacturer's label, if it says fast or slow, the fuse type is as it is labeled. If it says F it means the fuse is a fast-blow, and if it says T or S it means it is a slow-blow. Other letters will indicate unique fuses for your specific device.
                                      quote
                                        09-07-2024, 05:50 AM
                                      • jesterace
                                        Samsung UE46ES8000 Blown fuse but no other signs of short
                                        by jesterace
                                        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                        09-11-2024, 03:14 PM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
