Sony bravia KDL-48W585B
  • Jvel
    • Nov 2017
    • 24
    • Wales
    Hi. I have this tv and the main board failed it was just flashing red. Ordered a new board (ebay) fitted it and tv now flashes green and amber tv screen does flicker for a second when power up is attempted but stays flashing green and amber on the power light I cannot do anything with it via remote or side buttons. All help and suggestions greatfully received and thank you in advance.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony bravia KDL-48W585B
    Go to Sony website. Download firmware for your model. Unzip to USB stick. Turn on tv and put USB in tv. Wait 45 mins.
    • Jvel
      • Nov 2017
      • 24
      • Wales
      Thank you I will try this after work
      • Jvel
        • Nov 2017
        • 24
        • Wales
        All fixed thank you very much only took 3 mins after I plugged USB into tv.
        • freakaftr8
          • Oct 2012
          • 3743
          Good to hear!
          • JUCaESAl
            Sony bravia KD-65AF9
            by JUCaESAl
            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
            10-20-2025, 04:03 AM
          • reporter1979
            Sony Bravia KDL-40W2000 flashing
            by reporter1979
            Hello all!
            A lightning burned this TV, Sony Bravia KDL-40W2000 that shows the 3-flash error code.
            I have read old threads here about this issue and I'm writing this just to ask an advice.
            First I replaced the power supply board (25€) just to discover that the issue remains. Now I have the option to replace the mainboard too (the one with HDMI ports) for another 40€.
            Considering I'm not a professional technician just an enthusiast, what would you do? Thanx in advance.
            02-07-2023, 09:26 AM
          • shahnld
            Sony kdl 65xg9505 green amber blinking
            by shahnld
            Good Day.
            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
            01-03-2024, 03:05 PM
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • alegatorul
            sony bravia kdl-43w756c, no power, no sound
            by alegatorul
            the charger brick has 19,2-19,3 vcc
            changed the inverter board same result.
            where should i start?
            cheers
            11-15-2025, 10:00 AM
