Sharp LC-40DU68UT
  • fcisolutions
    • Jan 2017
    • 205
    Sharp LC-40DU68UT
    TV will power on and has sound but one side of screen has horizontal lines.
  • CapLeaker
    Leaking Member
    • 8325
    Re: Sharp LC-40DU68UT
    There is a difference between the two pictures. I would say clean the ribbon cable from main to tcon and the 2 ribbon cables from tcon to the LCD. See what that gives.
    • fcisolutions
      • Jan 2017
      • 205
      Thanks for the reply. I tried cleaning all the connections on the T-Con board going both ways. Still got the same result. Horizontal lines appear with what looks like the lines are not infrequent in their appearance but are not permanently visible. I was thinking of replacing the T-Con.
      • maxvalutech
        • 804
        • australia
        Had a similar problem on a 46" AWA which i bought replacement tcon and thought that's fixed OK but a few days later split picture with bad half background green colour back. Got rid of that again by very careful fitting tcon screen lead on problem side but as soon as set moved to another location fault returned. The real problem was the ribbon from tcon to screen fitting at the screen end which was in frame. Fiddling finally too much for the ribbon. The set had been out in the weather previously so in the end I scrapped it.
        • CapLeaker
          Leaking Member
          • 8325
          That's where I'd be looking next too and the tab bonds.
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • jaco2d
            Sharp 50bj2ke horizontal lines
            by jaco2d
            This is only my seond post and so far i am very impressed with the forums.
            I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
            The small white box thing in the pics is not the tv its a reflection from the window
            Any suggestions...
            11-01-2022, 04:45 PM
          • ninja_zx11
            Sharp LC-70LE650U vertical black and red bars
            by ninja_zx11
            70" LED TV is Sharp LC-70LE650U.
            Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
            07-07-2023, 11:27 PM
