Samsung PN50A450P1D Pink Screen Problem
    Screen problem occurred about 6 years ago. Since then the TV has been unused and in storage.
    Screen has a pink tint. See attached pics.
    Set has 5 boards. Part numbers are:
    BN44-00207A Power Supply
    LJ41-05309A Main Logic
    LJ41-05986A Y Main
    LJ41-05987A X MAIN with Sub Board
    BN94-02067B Main Board
    Any suggestions as to what board/s can be the cause of the problem will be appreciated.
    Re: Samsung PN50A450P1D Pink Screen Problem
    Run the test patterns. Unplug set,let sit 5 min. Unlatch the flat ribbon that goes from the mainboard to the logic board. Put a clip across pins 3&4 as shown in pic. Plug tv back in and watch the screen. If all colors look good, your mainboard is bad.
      tvtimmy
      Thank you for your reply
      Sent you a PM
        ***UPDATE***
        With the help of tvtimmy It has been determined that the X-Main board is causing the problem.
        Will replace the board and update the forum as to the results.
          Would it be too much to ask you to share with us the method to determine, the X-Main Bd. is the problem?
            See post #2 As to what was suggested for me do.
            I never did run the tests that were suggested. However before I did anything else I checked the fuse on the X-Main board and discovered it was blown.
            The following is the conversation I had with tvtimmy
            bedrck46, Before I follow your suggestion I have found that the
            6.3 amp fuse was blown on the X-Main board.
            Would you suggest that I replace the fuse and try the set again or would you suggest I replace the board?
            I have looked at the board and I can not see any bad caps or burn marks on the front of the board. I have not removed the board to check the back side.
            tvtimmy, Yes. Replace the fuse and check all the fets for shorts.
            bedrck46, I replaced the fuse The TV would not turn on. I also was getting TWO flashing green LED's on the logic board and also a relay on the power supply was clicking on and off.
            I then removed the fuse (it was still good Didn't blow) and turned the TV back on and now I am able to get the pink screen and also ONLY one green LED on the logic board if flashing.
            My thoughts are the X-Main is bad Your thoughts?
            Thank you.
            tvtimmy, Yes, the xmain is the problem.
            There are 5 x- mains for that tv, what is your board number?
            The most common one is very cheap at shopjimmy and even cheaper on ebay.
            At this point I have ordered a replacement board and will update this thread after I receive and replace the board.
              ***UPDATE***
              Problem resolved. Replaced the X-Main Board
                Good job!!!
                  Thank you
                    Sorry to revive an old thread.. but I have a similar issue to this but due to the picture distortion as well as the colour. I wanted to confirm the diagnosis was indeed the X-main board as well.
                    I have the same TV as the listed on above: PN50A450P1D.
                    The TV spent its time off for the prior week, went to flip it on and as it booted heard a loud pop and the picture looked like the images attached.
                    Found a popped capacitor on the power board which was replaced, but the TV still has a distorted & discolored picture. I ran the diagnosis (jump pins 3 & 4 with main board disconected) with no change in the picture, TV was only on for a few second before turning itself off.
                    Can this be traced to an X-main board failure?
                      From the previous posts I would think you have a bad X-Main Bd. One of the posts spoke to the many X-Main Bds for that model TV. Check and double check before purchasing to ensure you get the correct board for your TV.
